NEED HELP ON COSSIE STARTING PLEASE PLEASE PLEAS????
Old Mar 29, 2006 | 07:33 PM
vinnyd's Avatar
vinnyd
Default NEED HELP ON COSSIE STARTING PLEASE PLEASE PLEAS????
right hello again to everyone who has helped me on my way..lol
anyways, I have had this on going problem on my cossie, I had an electrical fault for many weeks now which I found to be the crank sensor among other things,
now I am getting a spark to my coil, and the car wants to start but for some reason I am only getting a spark to number 4 plug when I turn it over, but the strange thing is when I check each lead with a spare plug number 4 plug will spark number 3 will only start firing when it try's to start number 2 is the same but I get nothing from number 1 plug.
I have changed the phase sensor plus I have linked the coil pins out on the ecu plug an in turn I do get a spark from that on each plug,
I have changed the crank sensor, phase sensor, all new plugs, rotor arm, the cap is new, it can not be the leads as I do get a spark when I link the coil out????????????
I need help please if anyone has had this problem please tell..
I forgot soon as I turn the engine on I get a spark from the ignition module I think to which ever plug is engaged. even number 1, but I don't get a spark on 1 if cranking..
Old Mar 29, 2006 | 08:45 PM
jon@work's Avatar
jon@work
Are you sure you plugged the phase sensor in correctly inside the dizzy ?
Top wire on sensor goes to the pin nearest to the sensor itself.
Wrong = non start on early ecu's. Run faults on later ones.
Old Mar 30, 2006 | 06:16 AM
vinnyd's Avatar
vinnyd
yeah jon i just changed it for a spare one i had out ov another dizzy, i just changed it to the same way the other was fitted. it was doing the same thing with the other phase sensor.
i have fitted it so the green wire is connected to the left terminal in the dizzy.
i dont think my other sensor was faulty but i changed it anyway.
cheers
Old Mar 30, 2006 | 09:03 AM
jon@work's Avatar
jon@work
have you gone through the diagnostics on the other thread ?
Old Mar 30, 2006 | 03:18 PM
vinnyd's Avatar
vinnyd
yeah everything is fine now its doing all the right things now...but not starting..
all the relays are coming in fuel is there, i know am at the last thing now, i was sure it would have been the phase sensor.. am going down on it now. i am just woundering if that ignition amp is not sending a strong enough signal. its like the spark from the coil is not strong enough,
i have had it ticking over but only on three cylinders, its got to be something simple now.
am back on in abit..
cheers.
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Alun Gregory
Sep 6, 2015 09:40 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
