anyone ordered there zetec turbo pistons and rods from usa?
hi im starting to build a zetec turbo, i have already got the 2.0 mondeo engine and can either get 86mm or 86.5 calibra pistons (not sure which to go for 86 or 86.5)
my question is has anyone ordered there pistons and rods from the usa for there 2.0 zetec turbo build.
if so can you point me in righ direction, i.e a trusted site which you used as i want to order some pistons and steel rods for my build and noticed they are slightly cheaper over there.
i have noticed a few people have ordered there stuff from the us so can you please share the experience you had, and also a good reputable company to order off
many thanks
many thanks
many thanks
many thanks
i've brought eagle steel rods and je pistons from the states bought them from here www.nolimitmotorsport.com rods $330 and the pistons $429, i paid $100 posting they took a while to come next time i will use either dhl or ups, then i had to pay Ł130 duty cosworth have just done some steel i beam rods for the zetec which retail @ $500
thanks turboboss
cool could you please tell me what pistons and rods i will need for a 2.0 zetec silvertop?
as heard blacktop rods are difrent to silvertop rods?
or what steel rods will fit in a 2.0 zetec Silvertp engine, as might be able to get some c20let pistons for the build, however needs some steel rods, just unsure which ones will fit.
as im building a 2.0 full zetec turbo. think compression is going to be 7:4:1
as above
turboboss i have also seen that cosworth have just done some steel i beam rods and some nice pistions for the zetec black top
but can these be used in the silver top zetec?
Brian
but can these be used in the silver top zetec? Brian
Ooooh be careful mate, saying that your gonna build a zetec turbo may upset every cvh owner on the site
Im building a zt and im going for pistons from area six at c/r of 7.4:1
Good luck with it mate
Originally Posted by Hansenturbo
as above
Brian
about off boost Drivability" then i said "what about on boost power" screw drivability not Trending Topics
thelynx
what engine you building, also how much were ur pistons, as heard the pistons from area six are around 600 quid
also what rods you buying?
quality items though, designed for the job and not from another engine like the c20let ones!As for the rods im unsure at the min... Dont know whether or not im changing them as there good for about 270bhp with arp rod bolts... But im still undecided on this...
same here i dont know what to do stay with cast or go steel
however i wanted around 250-260 however i would be crapping it everytime i ragged it, if i kept my cast rods
theres just no point in spending 600 quid on a set of pistons, then the rod bends or melts and thats one of the pistons srcap.
then theres another 600 quid straight away.
think its better to have steel rods then you dont have to worry about what boost ur useing and also how much you rag the engine as you will know the rods and pistons will take it.
However im useing calibra c20let pistons in my 2.0 turbo build, but does anyone know if eagle rods will be ok to use and if i will be able to get them machined to fit the calibra pistons???
seen some here
http://www.newedgeperformance.com/in...PROD&ProdID=43
seen some here
Originally Posted by rightstuff
will the eagle rods fit the calibre turbo pistons then??
will the cosworth rods fit the calibre turbo pistons then??
no to both the calibra pistons are press fit and the cosworth & eagle are fully floating.. on my last zvh i ran standard rods with calibra pistons and @ 19psi the engine produced 311bhp and 292fbt on top of that for drag racing in used a 70shot of nos so the standard rods can take more then 270bhp.
old nitrous setup
311bhp
wow wasent you scared taking it that high incase the rods decided to leave through top of sump
so if the calibra pistons dont fit & are press fit and the cosworth & eagle
surely you can get them adapted to fit? or maybe get custom rods?
darn i bought a set of calibra pistons for 100 quid too :/
311bhp
