saph cossie wont start sparks and fuels but no go????
Old Mar 26, 2006 | 09:26 PM
lisa 23's Avatar
lisa 23
Default saph cossie wont start sparks and fuels but no go????
i just put another engine in my cossie theres sprark at plugs when turning over and can smell fuel on spark plugs when i remove them but it just wont start it try's to fire but thats it i have triple checked timing & phase sensor is set spot on & bought new spark plugs but it wont go any ideas i have spent a few hours every evening trying to get it running for a week now so any advice as iwant to get this engine run in before the shows start and still got loads of stuff to do to it before hand
any info apprieciated
Old Mar 27, 2006 | 09:17 AM
BMEP's Avatar
BMEP
It sounds like the “rotor phasing” is out.
Get the engine to TDC (compression) and make shore that the “arrows” on the cam sprockets are pointing to each other, remove the dizzy cap/dust cover and see if the rotor button is in the correct place. There should be a shallow “groove” on the dizzy’s outer base where the cap sits. The rotor button should be pointing directly toward the groove.
To give you an “approx” idea, the rotor button should be pointing toward 2 o’clock when viewed from the front of the car looking down at the dizzy.
Hope this helps
j.hammond1
30
Oct 31, 2021 05:28 PM
gcfcos
118
Aug 18, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
ginger1979
Jul 31, 2015 09:56 PM
