more problems
Old Mar 24, 2006 | 08:56 PM
THE RADMAN's Avatar
THE RADMAN
Default more problems
been having probs with my aircon so tried a diff p8 in my esc cos tonight just to see if it would make any difference,only started it up,didnt drive it,now when i plugged mine back in the car it wouldnt even start finally got it to go but it runs as rich as anything and barely idles,sounds like its on 2 cyls,cant give it any throttle at all,whats gone wrong now? looks like a coincidence now
Old Mar 24, 2006 | 08:58 PM
Damo V's Avatar
Damo V
You didnt send YOUR P8 to the gold platers while it was out did you?? If so the acid bath could have fried it
Sorry... I dont know...
But see Series1AJC's thread about his P8
Old Mar 24, 2006 | 09:00 PM
Damo V's Avatar
Damo V
https://passionford.com/forum/viewtopic.php?t=185671
Old Mar 24, 2006 | 09:11 PM
THE RADMAN's Avatar
THE RADMAN
damn didnt think of that one damo,lol
Old Mar 24, 2006 | 09:15 PM
Billabong's Avatar
Billabong
Are you having problems after fitting a certain chip, or is it just simply an aircon issue?
As for the new faults, ensure the ECU connector is fitted home firmly? Have you also performed the P8 ECU reset procedure (not 100% certain if this still applies with Pectel board, but think it does?) ?
Old Mar 24, 2006 | 09:33 PM
THE RADMAN's Avatar
THE RADMAN
the ecu part was just a coincidence it seems,started it this morning now its cooled down o/night and its fine again! had problem last yr with same symptoms so fitted new ect sensor,its only done a few hundred miles since then so surely it cant have packed up again? it deffo seems engine temp related as its fine from cold and plays up when its warmed up? what else could affect it apart from the ect?
Old Mar 25, 2006 | 09:46 AM
THE RADMAN's Avatar
THE RADMAN
up
Old Mar 25, 2006 | 09:58 AM
Graceland's Avatar
Graceland
Team HOTHOT!
have you chopped out the loom connectors in the engine bay that run along the chassis leg and connect the engine loom to the car loom? - if not, i bet that this is your problem - chop them out and hard wire (join the wires with solder) and i can safely say that the root problem will be cured
Old Mar 25, 2006 | 10:12 AM
THE RADMAN's Avatar
THE RADMAN
funny you should say that as ive been meaning to do it for ages,and have even got all the bits ready,is it best to tin both ends of the wires first or just twist the wires together and solder the lot?
Old Mar 25, 2006 | 10:15 AM
DaveEscos's Avatar
DaveEscos
ooooooh Damo you C*NT!!
Old Mar 25, 2006 | 10:18 AM
Graceland's Avatar
Graceland
Team HOTHOT!
cut back a couple of inches from the plugs either way, or untill you get to fresh clean copper, and join using fresh wire - that way you will not be stretching the existing wires at all.
then to seal, use heat shrink on each wire to seal it niceley, and then loom tape all together so it looks factory
If you are bothered about remembering which wire goes where, do it one at a time and using joining wires to suit
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
