2wd cossie brakes
Don't ask - I don't know
No, in a word. 2wd calipers are 4 pots which won't fit under standard S1 rims. I run Escort Cosworth 4x4 calipers and 283mm 2wd discs. They go (just) but don't plan on having any stick on weights on the inside on the rim as then the rim won't clear the calipers as they rotate - it's that tight. But they WILL fit.
TBH is depends on the width and offset of the rims you have. I'm not 'up' with sizes etc but ask in the general forum - someone there will know.
You've got to tap the bolts holes out with a M12 tap, and be careful when bolting them on as the bolts holes are fractioanally out, and for gods sake buy some high tensile cap head bolts to put them on with and nothing less!
Nov 3, 2015 04:08 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Red_bull
Aug 9, 2015 08:34 AM
