WHAT HEAD GASKET SHOULD I BUY
Old Mar 21, 2006 | 07:24 PM
jamie rst's Avatar
jamie rst
Default WHAT HEAD GASKET SHOULD I BUY
I am building a new engine for my erst so can any one tell me what head gasket is the best one on the market and where can i get it from,
here is the spec of my new engine
1600 low comp
stage 3 cylider head with double valve springs and a piper 285T2 cam
and i have got a stage 3 hybrid turbo
I am think of buying an ARP stud and nut kit for the head can any one tell me if they any good or not
thanks for any help
Old Mar 21, 2006 | 07:27 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Standard Ford item
Almost all the replies will be the same
Old Mar 21, 2006 | 07:37 PM
Oranoco's Avatar
Oranoco
Standard Ford headgasket.
While you're playing I'd bin the 285T2 and fit a Kent CVH35 or Newman
Old Mar 21, 2006 | 07:39 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
OE Spec Ford Gasket and Bolts.
Oh, and stick with the T2 IMO.
Old Mar 21, 2006 | 08:00 PM
jamie rst's Avatar
jamie rst
Thanks lads i will get order one tomorrow as i work at a ford dealership so i will get so discount i hope
Old Mar 22, 2006 | 05:48 PM
David Ramsey's Avatar
David Ramsey
What would be wrong with a group A head gasket?
Old Mar 22, 2006 | 05:49 PM
Oranoco's Avatar
Oranoco
The standard Ford one is fine well into silly power figures. Why spend cash on something that just isn't needed?
Old Mar 22, 2006 | 06:00 PM
David Ramsey
I never knew the standard one was that good. Wish I never just ordered a group a one
Old Mar 22, 2006 | 06:11 PM
Rallyesport's Avatar
Rallyesport
There are no gr. A parts for RST.
Old Mar 22, 2006 | 06:24 PM
David Ramsey
Got it from WOODFORD GARAGE, Ł35. Felpro one. This any good or should I have got a standard?
Old Mar 22, 2006 | 06:28 PM
biglee's Avatar
biglee
Audio specialist
think he means a grpA spec, and they are available,
ive taken the ford item well past 20 psi @cr of 10.9:1, and it was fine for a year or so, i wasnt nice to it tho and to be honest i was expecting it to appear out of the side of the head long long befoe it did, full respect for the OE ford rst head gasket
Old Mar 22, 2006 | 06:33 PM
T28 RST's Avatar
T28 RST
Ok then
Felpro
Old Mar 22, 2006 | 06:34 PM
David Ramsey
So what spec is the one I bought?
Old Mar 22, 2006 | 06:38 PM
jamie rst's Avatar
jamie rst
Cheers lads for all the help i have order one to day as i work at ford
once again thanks
Old Mar 22, 2006 | 06:47 PM
David Ramsey
Originally Posted by T28 RST
Felpro
What's wrong with these? I've never had them before.
Old Mar 22, 2006 | 07:30 PM
rsturbowhite's Avatar
rsturbowhite
iv never had eny problems with felpo one me rst ? yet
Old Mar 22, 2006 | 08:08 PM
Oranoco's Avatar
Oranoco
Felpro are fookin shite. Mine let go between cylinder 1&2 and my mates on his S1 went exactly the same way. I've heard of loads of people that have had grief. Send it back and ask for a genuine Ford one (not patern). If they can't get you one get your money back and get one from Ford yourself.
Old Mar 22, 2006 | 08:15 PM
Šhatter Box's Avatar
Šhatter Box
felpro fords all day long and the t2 cam kent 35
Old Mar 22, 2006 | 08:20 PM
Rallyesport
Felpro have a larger fire ring than the bore of a 1.6l CVH, it's intended for the 1.9l american CVH.
Old Mar 22, 2006 | 08:46 PM
DazC's Avatar
DazC
Which is normally aspirated and doesn't have a turbo forcing in extra air!
Old Mar 22, 2006 | 09:00 PM
Oranoco's Avatar
Oranoco
A man after my own thinking
dombanks
Sep 21, 2015 08:38 PM
Chopshop85
Sep 12, 2015 06:42 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
