FAO Esc cos wiring gurus...Problem found! UPDATED 01/04/06
Old Mar 19, 2006 | 05:35 PM
DaveEscos's Avatar
DaveEscos
Default FAO Esc cos wiring gurus...Problem found! UPDATED 01/04/06
My ign live feeds under the bonnet have gone dead. Black wire with brown line i think.
They are the ign feeds for the orig loom also I think. It now has a pectel loom
Does anyone know if these are fused anywhere?
OTHER than the fuse box and the aux fuse pod on the battery. Ive checked these and there are none blown.
Strange one.. indeed. Means the ECU is dead and wont start the car. (ive placed a temp live feed to get the car back home and locked up)
cheers
Old Mar 19, 2006 | 06:58 PM
Billabong's Avatar
Billabong
I take it you no longer have fuselinks....
BTTT for Dave
Old Mar 19, 2006 | 07:20 PM
le-claw's Avatar
le-claw
Black with brown stripe ?
Thats not a normal ignition colour....
Normally black and black/yellow stripe.
Old Mar 19, 2006 | 07:55 PM
DaveEscos's Avatar
DaveEscos
cheers googlebong
Ding, probably yellow.. come to think of it... deffo yellow
Old Mar 19, 2006 | 07:59 PM
xr4x4rs's Avatar
xr4x4rs
could it be the igntion realy
most looms will have a realy for all your igntion lives
worth a shot duno which one it is though sorry
Old Mar 19, 2006 | 08:15 PM
le-claw's Avatar
le-claw
so nothing at the coil ?
This comes from the ignition barrell efectively via the fuse board...
What loom do u have installed in the car ?
As the normal cossie loom pick's up its live from the main loom - black wire usually 25amp
Old Mar 19, 2006 | 08:59 PM
DaveEscos's Avatar
DaveEscos
running coil packs ding... I have a pectel loom. The orig ign live feeds it from the std loom.
no starter, fuel pump, ecu live .. just ign lights.. turn the key and nothing
BUT
feed a live to the engine bay ign live that USED to be live.. then hey presto.. everything starts
somethigns blown... but where is another story lol... all fuses are fine (that i can see)
Old Mar 20, 2006 | 06:51 AM
kjc300's Avatar
kjc300
Dave, there's a connector on the left hand side of the battery - sort of on the plastic surround. Make sure thats connected properly!! If you cant find it, follow the small wire from the starter motor bunch of wires I think it's blue and black!!
Old Mar 20, 2006 | 07:17 AM
DaveEscos's Avatar
DaveEscos
Kev, I checked the fuse block that is connected to the battery... and everything is as it should be. They are much thicker wires also. This ign feed is quite thin
Old Mar 20, 2006 | 07:31 AM
Dave Henshall's Avatar
Dave Henshall
i had them burn out on the back of mine - the copper had gone all black and fooked on the two main ones that go from the battery pos lug to the main fusebox - had to chop them back, and solder new tails on them both of about 100mm to get back to decent copper - i think someonw at some point had had the battery on cgarge left on the car and the acid had bubbled all over the top of the battery, cos thhose wires were manky as were the inside of the main cooling fans relay right next to the battery.
Old Mar 20, 2006 | 07:58 AM
DaveEscos's Avatar
DaveEscos
I dont think I have that problem Dave.. all the links are clean.
These ign feeds come up behind the right hand side turret... they must lead somewhere that's fused .. or unless they've burnt out somewhere...
if i cant find out.. ill re-install a new ignition live to the loom.. but id rather find out what has caused this
any suggestions to take a decent ign live from, either from the fusebox?
Old Mar 20, 2006 | 08:36 AM
Billabong's Avatar
Billabong
Is it the permanent live for the P8 (as you have ignition lights)?
Old Mar 20, 2006 | 08:59 AM
DaveEscos's Avatar
DaveEscos
No Bill.. ign feed
I wasnt aware P8 had a perm live?
Old Mar 20, 2006 | 09:17 AM
kjc300's Avatar
kjc300
Not there.......
get hold of the starter wires that come up from the starter and there's a thinner wire with them - follow that and it goes to the LEFT hand side of the battery looking at it. On the plastic surround is a plug - check that!! I had this with the exact symptoms and I found I'd slightly loosened the plug whilst faffing around with the wiring!!
Old Mar 20, 2006 | 11:36 AM
Damo V's Avatar
Damo V
It doesnt make sense the car not cranking till you give that wire a live?
That wire not being live with IGN on (as it was) shouldnt affect the starter cranking?
Have you checked EVERTHING electrical works>? Lights radio heated screens etc etc could just be the common old fuse box issue...
BTW IIRC the wire is black alone
Old Mar 20, 2006 | 11:39 AM
DaveEscos's Avatar
DaveEscos
thats EXACTLY what I thought Damo! I thought an alarm problem... as i couldnt crank etc..
BUT the alarm has nowt to do with the ECU and nowt to do with those ign feeds to the loom...
as soon as i connect a live to that ecu feed... hey presto
something is amiss.. but what!
Damo V's Avatar
Damo V
Or an alarm fault, that would cut the starter and IGN feed THAT is becoming my favourite option...
Old Mar 20, 2006 | 11:41 AM
St3V3_C's Avatar
St3V3_C
And putting the feed on to the ECU is backfeeding to bypass the fault?
Old Mar 20, 2006 | 11:43 AM
Damo V's Avatar
Damo V
Possibly.... either way the feed must be "backfeeding" some way, as that wire isnt linked direct to starter/cranking...
Old Mar 20, 2006 | 11:44 AM
DaveEscos's Avatar
DaveEscos
as a temp fix to get the car back to its locked up safety.
So IF its an alarm fault.. JOY OF ALL JOYS!
where the hell to start looking!?
Old Mar 20, 2006 | 11:45 AM
Damo V's Avatar
Damo V
They thing to try would be disconnect the Pectel loom from car loom at the IGN live wire, give the pectel loom a live from battery turn IGN on and try cranking, if it still doesnt crank, then it is a backfeed supplying starter relay etc
Old Mar 20, 2006 | 11:50 AM
DaveEscos's Avatar
DaveEscos
good call mate , will get on that asap.
Old Mar 20, 2006 | 11:51 AM
St3V3_C's Avatar
St3V3_C
The only proper way is to follow it all the way from the source testing for voltage as you go, and see where you loose it.
You might want to try finding where the wires from your alarm are spliced into the loom - test both sides of the same colour wires to eliminate the alarm.
Old Mar 20, 2006 | 06:39 PM
DazC's Avatar
DazC
Does it have a Vecta fitted to it?
They are common for relay contact failures....
Old Mar 20, 2006 | 07:42 PM
DaveEscos's Avatar
DaveEscos
no daz, long gone mate
Old Mar 26, 2006 | 06:29 PM
DaveEscos's Avatar
DaveEscos
right, update..
if i just give the ecu a supply.. the car wont engage the starter motor
if i give the dead ign feed a supply ( and the ecu) then the car starts... BUT
I can remove the keys witht he car still running, only way to kill the engine is to remove the temp +ve feed
SO it must be ign based related......
any ideas?
the als relays were plugged in the wrong way and overheated.. these were connected to the +ve ign feed under the bonnet.. this has caused the prob..
The alarm is fine.... just somethings killed the signal to the starter.. inturn killing this underbonnet ign live
Old Mar 26, 2006 | 06:32 PM
DaveEscos's Avatar
DaveEscos
and the ign live cable is black with a yellow stripe
Old Mar 26, 2006 | 06:43 PM
le-claw's Avatar
le-claw
Sounds like immboliser or burnt out wires and u need a this testing.
Try a local Auto electrician.
Old Mar 26, 2006 | 06:58 PM
DazC's Avatar
DazC
R26 is your ignition relay R24 is your starter relay....
Check for live feed on terminals 30 and 87 of the relays when the relays are engaged (assuming they click on and off with the ignition and cranking position)...
Old Mar 26, 2006 | 07:00 PM
DazC's Avatar
DazC
R8 is the engine management relay.
Old Mar 26, 2006 | 08:33 PM
DaveEscos's Avatar
DaveEscos
cool Daz! thanks for that!
Old Mar 27, 2006 | 02:23 PM
Damo V's Avatar
Damo V
Daz to the rescue again...
So at a guess its probably the relays or fusebox... If it isnt the alarm??
I'm still not convinced its not the alarm TBH
Why have the ALS relays failed? What was wired incorrectly? Pectel loom?
Old Mar 27, 2006 | 02:25 PM
DaveEscos's Avatar
DaveEscos
Im not speaking to you, you c*nt!
Old Mar 27, 2006 | 02:33 PM
Damo V's Avatar
Damo V
I was in the pub when you text me yesterday
Old Mar 27, 2006 | 02:35 PM
DaveEscos's Avatar
DaveEscos
im not talking about that!
Old Mar 28, 2006 | 06:47 AM
DaveEscos's Avatar
DaveEscos
its still there Damo!!
Old Mar 28, 2006 | 06:49 AM
Ryan's Avatar
Ryan
dave can u answer my pm's please.
u spud!
Old Mar 28, 2006 | 06:56 AM
DaveEscos's Avatar
DaveEscos
Ryan
Ryan's Avatar
Ryan
pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeas e
Old Mar 28, 2006 | 06:57 AM
DaveEscos's Avatar
DaveEscos
ok..
Yes
