Need an exhaust housing where can I get one from??????
Old Mar 16, 2006 | 01:07 PM
davidnormanuk's Avatar
davidnormanuk
Default Need an exhaust housing where can I get one from??????
Anyone know where I can get a standard exhaust housing from without any cracks new/reconned or second hand?
Dave
Old Mar 16, 2006 | 02:26 PM
SafeChav's Avatar
SafeChav
That place u rang for £70
Old Mar 16, 2006 | 02:30 PM
davidnormanuk
Just wondered if anyone had one a bit cheaper.
Old Mar 16, 2006 | 03:13 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
what u after mate the elbow part of a t 3 ?
Old Mar 16, 2006 | 03:22 PM
SafeChav's Avatar
SafeChav
I wish i'd of sold him one of mine by now everyones got spare elbows, and they've always got that same fucking stud snapped off too
Old Mar 16, 2006 | 05:56 PM
davidnormanuk
The Exhaust housing part. The part that covers the exhaust turbine type thingie. You can see the cracks on my .48 housing. Hmmm could this be the reason for so much lag?
Old Mar 16, 2006 | 06:03 PM
SafeChav's Avatar
SafeChav
OMG that crack is massive compared to mine
Mine was laggy as fuck and as i said i even had the screw completely removed from the bleed valve and it still wont hold more than 6psi.
Definately a contributing factor
Old Mar 16, 2006 | 06:19 PM
davidnormanuk
Daft thing its was boost at 15psi but took ages to get there. Can't imagine how fast the turbo must of been going to be able to spool up. Just aswell its got a 360 degree bearing in n all hope not much damage has been done. No smoke or play on the shaft so think I've got away with it.
Old Mar 16, 2006 | 06:23 PM
SafeChav's Avatar
SafeChav
It will still be spinning at the same speed, but its taking longer to get there because the wastegate is leaking so its not as effecient as it should be. Its amazing the difference though, even though its cracked its not like you can see through the crack, just a hairline crack but it makes all the difference.
Old Mar 20, 2006 | 02:20 PM
davidnormanuk
Anyone else that can help with this. Looked into getting this one repaired at my work but it would need specialist equipment to do it as it would crack again if not done right.
Old Mar 21, 2006 | 09:04 AM
biglee's Avatar
biglee
Audio specialist
hi mate, i have several of these so i will let you have one for the grand total of 20 quid, plus your postage if you want it? pm me let me know mate.
that may just be a hairline crack but we all know what happens to metal when it gets to 400 degrees, .....
and now the crack is the size of a house!
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
