Boost question
Old Mar 16, 2006 | 08:34 AM
davidnormanuk's Avatar
davidnormanuk
Default Boost question
Hi all,
I've replaced my exhaust housing for a standard one as it was far too laggy.
When I am on boost sometmes the car pulls great then other times it seems to be holding back and I get like a restricted noise as though I'm hitting the limit of the actuator. When its doing this it doesn't boost over 10 psi then when I back off and put back on it hits 15 psi and pulls great. i'm assuming its most probably the actuator but throught I would get other peoples views on it. The hoses I have on are sfs hoses so that shouldn't be a problem.
Dave
Old Mar 16, 2006 | 10:20 AM
Rick's Avatar
Rick
Are you running the amal valve?
Old Mar 16, 2006 | 10:32 AM
davidnormanuk
No just a bleed valve. I am thinking though could it be bottlenecking at the bleed valve as its only tiny? I am gonna get a working amal valve and see if thats.
Old Mar 16, 2006 | 10:36 AM
Rick's Avatar
Rick
Won't be that mate, the bleed valve's job is to bleed of pressure, it doesnt flow any air so can be tiny. Sounds more like actuator.
Old Mar 16, 2006 | 10:49 AM
davidnormanuk
I'll see if I can get hold of one that I know works and take it from there.
Old Mar 16, 2006 | 11:41 AM
SafeChav's Avatar
SafeChav
How new is the turbo. Its unlikely but there is a chance your wastegate housing could be cracked. When mine went i noticed a lack of boost and it got to the point where i actually took the screw completely out of the bleed valve and it wouldn't boost higher than 10psi peak but dropped down to 6psi higher up the revs.
It was worth a mention but seeing as yours is boosting higher sometimes the actuator seems more likely.
Old Mar 16, 2006 | 11:49 AM
davidnormanuk
I've just replaced the housing for a smaller one due to it being too laggy but did notice a slight crack on it where the plate covers the hole about 2mm long. I will be getting a good one when I can find one but the one that was one it previous was even worse at least 2 cracks on either side of the hole about 3-4mm long. Can I weld this up and machine it flat?
Old Mar 16, 2006 | 12:14 PM
SafeChav's Avatar
SafeChav
I would show you the picture of mine but i cant find it. The cracks in mine didnt look like anything significant but they made so much difference. If your waste gate has any kind of crack then its not doing you any favours. I doubt very much whether welding and machining it would last very long, if you can do it yourself you dont have a lot to lose though as its scrap anyway......
Old Mar 16, 2006 | 12:27 PM
davidnormanuk
Just had a quote for a reconned one £70 I'm gonna have a look around to see if anyones got one.
Old Mar 16, 2006 | 01:06 PM
SafeChav's Avatar
SafeChav
I've got a spare turbo in the shed i robbed my housing off and i was going to get another housing, not for £70 though
Quite sought after though i would of thought as its common for them to crack.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
