Best oil for S1 (again)
Ask Oilman on here! I brought a load from him at a really good price. He gives discount to Passionford & RSOC members and you get even more of a discount is you do a bulk order. He recommended I use Silkolene Pro S 10W 50 and it really is spot on. My engine loves the stuff
I personally run 10w40 Mobil 1 Fully Synthetic, mainly cos my mate works for Renault and gets it for me free, but i know theres a lot of controversy about fully and semi synthetic oils.
i was told fully synthetic is no good unless its benn run on that since new, and magnatec is no good for theses engines incase it pulls the carbon out of the liners causing a loss incompression.
You can't run a new engine on Fully synthetic as it needs to run in, once run in the oil needs to be changed for better oil. That was the case with older engines, not sure about the ones that are now bench run in.
10w 50 and 10w 40 are the same thickness the last number just ie 50 represents how much heat it can take
you 100% want to be using fully synthetic as the heat from the turbo will cook other oils into water but dont mix fully synthetic with non fully synthetic not even semi synthetic oils
deathrider666
Sep 28, 2015 06:12 PM
