CLUTCH ADVISE NEEDED
hi people just got my first rs turbo but have a few queries on the clutch well the guy i bort the car from says it has a sports clutch but he says it really needs a paddel clutch because in high revs it slips something bout the flywheel turning to fast for the clutch .
what clutch would cue this probs because it goes like hell then it slips
all help is great thanks guys
as im not 100% sure what the bhp is this is what im running maybe you can get a rough idea:
Engine Created by Grove
Low Compression Bottom End.
Gosnay's Slightly Machined Bores and Skimmed Pistons.
Gas Flowed Cylinder Head with a Piper Cam Shaft and Followers. Platinum Spark Plugs.
1750cc Engine
Actuator
Large Garrett T3 Turbo with Modified Blades and 360 Degree Thrust Bearing
K + N Filter
Pace Intercooler System
Uprated Fuel Pump
5th Injector
Ammed Bajoo Super Chip
Boost Running at 18 PSI
Blue Samco Hoses
Bailey Dump Valve
Sports Clutch
Full Mongoose Stainless Steal Exhaust
Sierra Cosworth Pads, Discs, Callipers and Breaks
Adjustable Konis with Eibach Springs
1750cc Engine
Actuator
K + N Filter
Uprated Fuel Pump
5th Injector
Blue Samco Hoses
Bailey Dump Valve
Sports Clutch
cool where bouts???? i herd that the ap paddle clutch is not really designed for everyday cars there really only to be used for racing etc but thats what i got told. Do you think this will cure my problem with the sliping of the clutch in high revs because just as it picks up on then the boost kick in then it hits bout 4.5 -5k in the revs and just slips out and rev like hell ????
all help is preciated as not really clued up on these things yet i really want to get this sorted sooner than later
cheers bud
cheers bud
Well, we are in Norfolk too. About 10 miles NW of Norwich.
An AP uprated Organic will be OK, but a Paddle will be better IMO. Unless you are about 8 stone, you should be able to handle it OK. There are people on here running Organics up to and beyond 250bhp, but they won't stand as much launching IMO.
Converting to the later Non-ratchet pedal and larger quadrant will make th pedal feel lighter, if you struggle.
As always, I highly recommend a refaced flywheel when fitting a new clutch, I can help with this too.
I have used an AP Paddle that is further uprated to the 'normal' one on the road with no problems and currently have an Alcon 6-Paddle, which again is fine. Give yourself a couple of days to get used to it and you will be fine.
cool ok so where bouts is this place that might be be able to help is there somewhere in norwich so a AP paddle it is then does this place supply and fit the clutch how much am i looking at all in all
cheers mate
cheers mate
jessie_rs
11
Jun 3, 2019 04:57 PM
kosienutter
31
Aug 22, 2015 09:55 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
