temperature guage keeps going up and down....
Old Mar 11, 2006 | 04:26 PM
BA's Avatar
BA
Default temperature guage keeps going up and down....
as above.... if i start the car and let it warm up it get to a certain temperature then the guage just drops..... dad says this is when the thermostat is opening but i've never seen this happen on any other car i've had.... then i was driving down the a12 at about 70 and the temp guage was going up to the top of NORM slowly, then dropping to the bottom of NORM, then slowly going back up then down etc etc..... when i slowed down to about 40 it evened out in the middle... i've recently changed the thermostat and housing and the temperature sender.... anyone got any ideas why it might be doing this??
thanks.
Old Mar 11, 2006 | 06:52 PM
James Raby's Avatar
James Raby
The wire itself at a guess, might need cutting back and a new enfd putting on
Old Mar 11, 2006 | 06:56 PM
SafeChav's Avatar
SafeChav
Disconnect the sender wire and earth it, if the gauge rises to the red then i'd say it was the sender. One car i had the gauge would go up to normal, but as it got hotter and approached the fan cutting in it would go back down and the fan would cut in on the cold section, i never really looked at it to find the fault but im sure it was the sender.
Rick's Avatar
Rick
sounds cool, i want mine to flap too. It's borin and sits 1/3 way up all the time
Old Mar 11, 2006 | 07:05 PM
James Raby's Avatar
James Raby
it waves Rick, it doesn't flap
I like a gauge thats polite to you
Old Mar 11, 2006 | 07:32 PM
SafeChav's Avatar
SafeChav
Are you lot ever serious about anything ever???
Old Mar 11, 2006 | 07:39 PM
James Raby's Avatar
James Raby
Usually, you have to loom deep into some of our posts to get the answer
mind you I did answer it first time round
Old Mar 11, 2006 | 10:17 PM
BA's Avatar
BA
do you mean the wire to the sender?????????????
Old Mar 12, 2006 | 08:46 AM
James Raby's Avatar
James Raby
yup, mine gave way on the way back from TRAX last year
It have dodgy readings
Old Mar 12, 2006 | 10:09 AM
BA's Avatar
BA
thanks
15
Oct 7, 2015 03:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Derek Burleigh
Sep 16, 2015 06:27 PM
Apr 14, 2004 02:14 PM
