has any1 got any decent vids with wastegate chatter/flutter.
ive searched the boards but all the results that come back are old and the files are gone
has any1 got any please?
your waste gate never chatters or flutters...
any noise you hear is the turbo stalling..
how many times
how many times
if the turbo stalled it would break, cos the inlet and exhaust side would spin at different speeds but 1 shaft cant do that. the exhaust gas still pushes it round the right way, the noise is the compressed inlet air being forced out through the compressor blades and it sounds cut-up.
its like wistleing trough a fan, the fan doesnt stall, does it?
and every1 knows what u mean when you say chatter
and cheers T28
Turbos do break, when not running dvs. and all the little pieces go through the intercooler and kill engines.
if it hasnt happened.............it will ,maybe not today maybe not tomorow, but soon!
i dont see how whistling through a fan can be anything like 30psi going the wrong way through a small turbine?
Never had a turbo go wrong through not running a dumpvalve and have never run one
They never came out the factory with dumpvalves did they well most of them never
http://www.btinternet.com/~knight_ne...chatterbox.wmv
They never came out the factory with dumpvalves did they well most of them never http://www.btinternet.com/~knight_ne...chatterbox.wmv
i think most do have them. cossies deffo do.
Failiure may be an extreme circumstance but i have known it happen to a mate stage 3 cossie. snapped the turbine shaft and shattered the turbine, engine dead
the reason some didnt have them from factory is because standard boost isnt enough to cause damage, but up the boost as most people do and you need to take into consideration the extra stress this could put on the turbine, its like using a standard head gasket at stage 3 you would expect it to fail because of the extra boost and stress, so you would fit a grp a gasket to make it reliable.
most cars do come with dump valves, and all the turbo cars ive had the 1st thing i do is remove them. ive never had a turbo fail, i agree it wont make them last any longer but the noise is oh so good. lol
some people do take things seriously on here.....abit to serious if u ask me!
Stop trying to impress people with your infinate wisdem when all the guy wanted was to hear some chatter!
Here's a video of my Zetec Turbo Fiesta from last night. 20Mb and only one minute, DivX is on its way!
http://s54.yousendit.com/d.aspx?id=1...N3IFNXCR3ZKJEB
) and i wouldnt buy a grp a gasket cos theyre shite,get a mhg!was a .63 t34 by the way on my saff
and the dv was actually known as a noise suppressor,so that the execs who bought it couldnt hear the chatter,so wouldnt think theyd broken it
http://www.megaupload.com/?d=3M0HWZWJ
download top rite but its a big file lol 160meg
but theres a quite bit of chatter from my cosy and a maestro turbo
Originally Posted by rs shawn
Anyone got a 3gp version so I can show my disbelieving mates what chatter sounds like pls after I've bluetoothed it to my phone.
irtza Thanx mate.
I've found a load via google, but don't know which is good/bad/wanky/the best
Any ideas on ones you recommend ?
http://www.google.com/search?complet...=3gp+converter
So correct me if im wrong, if i take my dump valve of my focus rs ill get compressor stalll/ chatter.
I got a new turbo going on this week or the next so might try it for this week.
how many times
how many times
and cheers T28
a) what is SO appealing about hearing your boost being forced through the compressor blades?
b) its becoming a bit chav /
Kiran1600E
11
Oct 2, 2015 11:35 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
The Enigma
Sep 29, 2015 10:31 AM
