is it really worth it ???
No...not in my opinion....I did it with a 2wd cooler a few years back. I wouldn't bother again....just look out for a second hand GRS imo.
Unless your goingBIG power when maybe 2 cossie coolers
i guess it would be alot easyier to plum a intercooler in that the inlet and outlet pipe on the same side
Has the standard standard intercooler got to be changed when the boost is turned up past 10 psi, or what bhp can they take ???
Ben
Ben
Originally Posted by Rick
depends how u drive. upto 14psi is fine in short bursts, after that u lose power.
i will only use the car at weekends and cruise nights really, and i don't really drive it hard anyway
could just put my hand in my pocket and buy a intercooler i guess.
Ben
For cheapness in comparison Cos coolers area good upgrade.
Keeping existing radiator? You may have to cut the bottom of your bumper out to fit the cooler infront of the rad at the bottom of the car.
Hoses: two options for fitting. Reverse charge carrier then pipe up the left-hand side straight to carrier, or keep original carrier and buy some hosing which comes back on itself, then run some pipework over the top of the intercooler then up the right-hand side fixing onto the original carrier boost hose.
