4x4 Cossie front diff removal? Engine out of car!
Old Jul 27, 2004 | 12:09 PM
SPADGE's Avatar
SPADGE
Default 4x4 Cossie front diff removal? Engine out of car!
Is there a knack to removing front diffs from a 4x4 cossie engine or is it just a matter of struggle until it pops out
Cheers Spadge...
Old Jul 27, 2004 | 12:16 PM
St3V3_C's Avatar
St3V3_C
It was a right bitch...
The driveshaft that goes through the sump needs to come out, and it might help to loosen the engine mounts and push the engine over to the other side.
I guess it's catching on the rack right? It might be easier to take that out as well.
HTH
Old Jul 27, 2004 | 12:18 PM
St3V3_C's Avatar
St3V3_C
re-reading - is your engine out?
Old Jul 27, 2004 | 12:28 PM
SPADGE's Avatar
SPADGE
Like the title says yes the engine is out!
Old Jul 27, 2004 | 12:54 PM
SPADGE's Avatar
SPADGE
Problem sorted
I discovered that removing the last 17mm bolt securing it to the sump helped a lot
Old Jul 27, 2004 | 01:17 PM
St3V3_C's Avatar
St3V3_C
Originally Posted by SPADGE
Problem sorted
I was going to say are you sure all the bolts are out but didn't want a thanks for stating the bleedin' obvious post
Old Jul 27, 2004 | 01:41 PM
Spiky's Avatar
Spiky
Problem sorted
track.focus'd
Aug 12, 2015 05:53 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
