FITTING 17's PROS AND CONS????????
Old Mar 6, 2006 | 12:46 PM
COSSIE 1's Avatar
COSSIE 1
Default FITTING 17's PROS AND CONS????????
Ive got a s2erst an ive got the standard 15" rims fitted at the mo, im toying with the idea of fitting maybe rs 7 spokes or rs mondeo 7 spoke soft spokes rims with a 205/40/17 tyre, thing is the car is fitted with a spax sportskit which is fairly bumpy at the mo, if i was to fit the 17s will the ride comfort be alot worse than the standard rims?? also will the rims fit straight on and will they touch the bodywork on full lock and 4 up?? cheers guys ..............p.s im not looking at changing the suspensin setup b4 any off say change to konis etc
Old Mar 6, 2006 | 01:01 PM
andysrs's Avatar
andysrs
Default hi
I you keep to 35 et offset and you havnt got rear discs you should have no probs, if you have rear discs and its lowerd it will catch the rear bodywork the only way round that is a differant offfset on the rear with spacers on the front which is want im doing at the momant.
Old Mar 6, 2006 | 03:15 PM
COSSIE 1's Avatar
COSSIE 1
nope havent got rear disks so should fit ok then, what about ride comfort over standard?
Old Mar 6, 2006 | 03:20 PM
thelynx's Avatar
thelynx
I had mine lowered 25mm and ran 205/40/17's and it never rubbed with 4 up... But handling was wank with 17's....Which you want looks or handling?
Trouble is rs 7spokes look the nuts
Old Mar 6, 2006 | 03:35 PM
andysrs's Avatar
andysrs
Default IF YOU WANT
IF YOU WANT SOME MINT SEVEN SPOKES MINE ARE FOR SALE
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=8042767881
Old Mar 6, 2006 | 04:12 PM
adamS2RST's Avatar
adamS2RST
How low is the car? 7 spokes are 7 1/2" wide. Mine used to catch on a 25mm drop with just a passenger ! I do run rear discs though.
Old Mar 6, 2006 | 04:33 PM
andysrs's Avatar
andysrs
Default MINE
Mine are -20 there very wide with 7.5j,s and rear discsthats why there coming of
Old Mar 6, 2006 | 05:38 PM
kl-mortiss's Avatar
kl-mortiss
iv just fitted 17'' to my s2 and its lowwerd 45m and its not good they scrape the aurches im still tryiing to work out what to : do ive been told that the only way around it is to cut the lip of with a grinder our higher the car back up . its a nightmer because it looks so good with 17'' down low.had 16'' before no problems but its to late ive got the wheels now.
Old Mar 6, 2006 | 08:28 PM
James Raby's Avatar
James Raby
Just change the springs, -45mm on an RST is silly
If you stay with 15's, it'll handle just perfect with a nice suspension setup, bugger wheels = more risk or upsetting handling and making it a bumpy ride
I would also adjust the top knob on each shock to see if you can make it smoother without making it handle like jelly
Old Mar 7, 2006 | 09:13 AM
COSSIE 1's Avatar
COSSIE 1
thing is i like the standard rims but 17s do look nice , what ill prob do is refurb the standard rims and put nice tyres on and run them for abit
Old Mar 7, 2006 | 09:17 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Mine handles ok on 17's. Not that I have much choice in the matter
Old Mar 7, 2006 | 03:31 PM
James Raby's Avatar
James Raby
Tony, you could do what Christian has, I also have the same brakes as you
Sure 16's is a possibility??
Old Mar 7, 2006 | 03:46 PM
Tony Turbo's Avatar
Tony Turbo
Yeah, a motorsport 16" will fit. Unfortunatly I have more important things to spend the money on, like more power urgh urgh urgh!
Old Mar 7, 2006 | 03:56 PM
James Raby's Avatar
James Raby
Sell the Mo's to pay for the 16's - job done
Old Mar 7, 2006 | 03:59 PM
Tony Turbo's Avatar
Tony Turbo
No, not driving it around on 16's on the road.
Old Mar 7, 2006 | 05:27 PM
kl-mortiss's Avatar
kl-mortiss
16'' just look to small.
Old Mar 7, 2006 | 06:24 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
16in all the way on any Mk3/Mk4 Best for every reason!
Brakes big enough to stop a train would fit under 16in wheels so if your brakes dont fit, your brakes are for show
IMO of course
matman
Sep 9, 2015 05:45 PM
jamie956
11
Aug 25, 2015 11:51 AM
track.focus'd
Aug 12, 2015 05:53 PM
Ben26
Aug 11, 2015 04:19 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
