Next Update....Getting there...
Old Mar 5, 2006 | 06:16 PM
Default Next Update....Getting there...
Slow progress today....but its nearly there as you can see...i wonder if it will run! ...i just KNOW i am going to forget to do something...LOL.
Old Mar 5, 2006 | 06:17 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Looking good
Old Mar 5, 2006 | 06:20 PM
Sticky.'s Avatar
Sticky.
Nice one mate
Old Mar 5, 2006 | 06:23 PM
Ryan's Avatar
Ryan
Old Mar 5, 2006 | 06:24 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
comin along
Rene's Avatar
Rene
cant believe ur still alive
good on u mate
Old Mar 5, 2006 | 06:33 PM
GARETH T's Avatar
GARETH T
nearly there
Old Mar 5, 2006 | 06:34 PM
Zetecfiesta's Avatar
Zetecfiesta
looking very good now mate!
Old Mar 5, 2006 | 06:35 PM
James-W's Avatar
James-W
Your photography skills seem to be coming on no end mate.
Seriouly coming on good.
Does the engine have stadard internals apart from the pistons or was it overspecced?
Old Mar 5, 2006 | 06:45 PM
Paddy's Avatar
Paddy
Legend
It looks very shiny which is good, the rest of it I have no idea what it does
Whats the silver covering stuff over the pipe that normally go's to the airbox/filter thingy?
Old Mar 5, 2006 | 06:49 PM
Its a phone camera fooking great with the auto focus!
The engine was built for 600bhp I did alot of research...listening mainly to Julian Godfrey who rated the std conrods to 600bhp and a std crank to 800bhp (these are what he has seen in rally cross engines so i guess knows his stuff!)..I used a good set of std con rods balanced them...a brand new std crank...genuine cossie racing forged pistons using genuine std bearings which i was told were the best,Grp A bolts...using the EEC4 escos 200 block with oil jets..again the best block there is with liners to .25 to strengthen the walls up,plus WRC long studded...to keep the head down with over 2bar boost!...Then using the BEST head gasket you can,the WRC 4 layer job....lairy cams with double valve springs.
As you all know Rod had a block failure at over 900bhp....and i consider he wasnt using the best ie the EEC4 one (maybe he was..not sure LOL)...so block no probs...crank no probs...rods...on the limit at 600bhp was going to get them shot peened this rates them to 700bhp,but decided to leave std as its a road car so no real abuse..BUT as the aim is max 550bhp no probs at all.
Old Mar 5, 2006 | 06:50 PM
Billabong's Avatar
Billabong
Turbo hanger, fluids, air filter
Making good progress there Phil, ETA for mapping? - let us know if you're passing this way and I'll buy you a pint.
Old Mar 5, 2006 | 06:51 PM
Paddy...thats the turbo to intercooler pipe...samco one wrapped with foil
Old Mar 5, 2006 | 06:53 PM
Billy...thats the flaw..i have no turbo hanger...got to get a bailey one...but they are a rip off price ...I found i have no hose for the air filter
Karl has sent me a map that will be 95% there..safe aswell...with my monitering equipment i will see what its like....to get the max i will go to him for the final setup
Old Mar 5, 2006 | 07:23 PM
James-W's Avatar
James-W
Sounds a nice spec Phil didnt know about the crank upto 800 I thought it was around 700 agreed that Julian is THE DON his engines are mental.
Can see your point of view all diy as going to a tuner and handing them a check seems a bit boring.
Good luck with rest of the swap sound like its going to be pretty plain sailing from now on.
Btw Phil was this your old saph went into your photbucket album looking for pics of the F-car and found that who owns it now?
Looks mega.
Old Mar 5, 2006 | 07:44 PM
Ryan's Avatar
Ryan
Phil just a question you've used a 2wd Inlet? and not an EECIV one?
I know your running a spacer plate, but i thought the elbow was restictive way before the air volume in the plenum cover was?
Old Mar 5, 2006 | 07:56 PM
Hi Ryan...thats a 4x4 cover with a 10mm spacer...the standard 4x4 inlet setup was good for 460bhp...add the spacer and over 500 easy...the reason being is the space between the trumpets and the cover...10mm making it optimum,the elbow and in is bigger than the 2wd aswell...a 2wd with a 10mm spacer setup recently made 490bhp!..So over 500 wont be a problem
In any case i have a EEC4 cover in the wings if this seup up fails...but TBH it wont as its been tested already!
JHW.....some bloke is making it into a track car....didnt look like that when i sold it...That was the car to get me into all this shit and the Bosch..so big up
Old Mar 5, 2006 | 08:00 PM
Ryan's Avatar
Ryan
ahh cool
Old Mar 5, 2006 | 09:33 PM
aduz's Avatar
aduz
Old Mar 5, 2006 | 09:59 PM
rstoughy's Avatar
rstoughy
Looks good M8
Old Mar 5, 2006 | 10:02 PM
capri-rs's Avatar
capri-rs
in case you dont use your eec4 plenum.sell it to me
coming along nicely now phil
Old Mar 5, 2006 | 10:45 PM
dave cos4x4's Avatar
dave cos4x4
not far to go Phil.
Old Mar 5, 2006 | 11:48 PM
tregmatt's Avatar
tregmatt
top work
Old Mar 6, 2006 | 08:19 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
He hasn't got the EECIV plenum yet .
Old Mar 6, 2006 | 08:21 AM
Dont u think 600-550 is asking a lot of a t4 turbo??
Old Mar 6, 2006 | 11:58 AM
600bhp was when i was goin GT35 Its now a 500bhp plan...possible up to 550bhp as the T4 aint a totally std one Have to wait till she gets rollered..LOL.
Old Mar 6, 2006 | 12:02 PM
SPADGE's Avatar
SPADGE
Phil the pipe is on its way and will be with you tomorrow
Your old saff is now owned by a geezer not far from me and he came to me a while back for some bits and bobs to re-build it
Old Mar 6, 2006 | 01:34 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Well done Phil. Glad its getting there
Old Mar 6, 2006 | 01:42 PM
AlexF's Avatar
AlexF
your not going to prove it are you?!
ALex
Old Mar 6, 2006 | 01:54 PM
Mike Rainbird
Caraholic
ALex
Don't be silly . He can pretend it's any bhp he likes to think it is if he doesn't do that .
xr-stu
21
Aug 26, 2007 03:27 PM
frog
Aug 6, 2007 07:10 AM
Carlsworth
30
Jul 11, 2007 12:20 PM
cfoster
29
Jul 5, 2007 10:48 PM
cossiemanden
Sep 22, 2004 01:52 PM
