zetec turbo and t3 manifold?
Old Mar 5, 2006 | 05:48 PM
rst in breaking's Avatar
rst in breaking
Default zetec turbo and t3 manifold?
how does this work? i know new studs have to be drilled, but does anything have to be donewith the old ones? and do anystuds line up? are the ports a perfect match?
Old Mar 5, 2006 | 06:34 PM
Ginge !'s Avatar
Ginge !
just finding my feet
no the best idea
there IS a way to do it but ill have to show ya
PS: can i have my ecu back you removed from cowboi's house as that is MINE and was NEVER his
Old Mar 5, 2006 | 06:37 PM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
drill new ones.
no zetec ones line up
but the ports line up when new ones are drilled
whats your way bal?
Old Mar 5, 2006 | 06:38 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
get a plate made
Old Mar 5, 2006 | 06:51 PM
Ginge !'s Avatar
Ginge !
shhhhhhhhhhhhhh its top secret
Old Mar 5, 2006 | 06:52 PM
DUDE_SWEET_FRST
depends what cars it on.
i got a plate from interpro, and its moved the turbo too close to the rad
Old Mar 5, 2006 | 06:56 PM
Ginge !'s Avatar
Ginge !
wait till the engine mount wears out too,,,,,,,, that when the REAL fun starts
Old Mar 5, 2006 | 07:03 PM
DUDE_SWEET_FRST
dont need to wait
i reckon 1st time i give it some revs its gona smack the rad
Old Mar 5, 2006 | 07:05 PM
DUDE_SWEET_FRST
i reckon theres about 1cm there
Old Mar 5, 2006 | 07:10 PM
XRT_si's Avatar
XRT_si
Iam in the same boat
Mine is going in the XR2 so rad clearance does create a little problem
Old Mar 5, 2006 | 07:12 PM
Ginge !'s Avatar
Ginge !
pmsl.......... what plate it that
but cant be that bad if you can get a camera in there
Old Mar 5, 2006 | 07:34 PM
Brasso's Avatar
Brasso
Yo. Have you got the vibratechnics gearbox mounts?? Mines roughly as close as yours and hasnt touched yet under hard track use. Not ideal tho! I think I'll be gettin an area-6 tubular manifold and fook it all off above the gearbox when I get a T34.
Old Mar 5, 2006 | 07:42 PM
Ginge !'s Avatar
Ginge !
fook that mate,,,,,,,, id rather drill the engine than have that option
Old Mar 5, 2006 | 07:56 PM
DUDE_SWEET_FRST
tell me about it
gona have a go at making a custom actuator bracket. tuck it under the turbo abit more. shoulg get another cm then
Old Mar 5, 2006 | 10:07 PM
Cowboi's Avatar
Cowboi
how about blue tacking the manifold on the block?
that might give u a bit more clearance
Old Mar 5, 2006 | 10:17 PM
MOONDUST FRST's Avatar
MOONDUST FRST
Just how mine was but never had a prob, sayin that though if a mount does let go kiss goodbye to the rad So not ideal no but like i say mine was fine
Old Mar 5, 2006 | 10:54 PM
XRT_si's Avatar
XRT_si
Looks like a mint set of engine mounts for me then
Isnt there a way of sealing the last stud that goes through th oil way?
Old Mar 6, 2006 | 08:43 PM
Ginge !'s Avatar
Ginge !
fook me,,,,,,,,, if you drill the block and make it to the oil galley
how deep do ya wanna drill it,,,,,,,, its risky enough when the water galley is drilled through,,,,,,, why would you wanan keep drilling
robnock
21
May 13, 2019 05:29 PM
mrknifey
Aug 30, 2015 11:48 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
