Running problems
Old Mar 4, 2006 | 02:24 PM
mattrst90spec's Avatar
mattrst90spec
Default Running problems
Hi
I've owned my 90 spec turbo for 3 years & never had any real problems with the engine until today.
I went to start it as normal this morning & it wouldnt start so i towed it down the road & got it running.
Once running every time i tried to rev the car it back fired alot, it would idle ok no problem, it also stopped & started on the key 3 or 4 times no problem.
I then restarted it & let it idle for 10 mins or so to get temp up to normal then went for a little drive, it went ok for about a mile ok then started to back fire again & stopped!!!!
Now i cant get it to restart even by towing it, any idea's people?
Matt
Old Mar 4, 2006 | 03:20 PM
andyt's Avatar
andyt
plugs maybe
Old Mar 4, 2006 | 03:53 PM
mattrst90spec
I had new plugs 3 months ago, i change oil, plugs, filters etc every 8 000 miles, i've also had new fuel pump & fuel filter in the past 3 months aswell.
Old Mar 4, 2006 | 06:13 PM
TheMightyBoosh's Avatar
TheMightyBoosh
I should hope you change your oil more regularily than that. IMO.
Old Mar 4, 2006 | 08:00 PM
rs nutta's Avatar
rs nutta
check the plugs are still ok first. then check the plug leads havn't got any condensation in them. if that doesn't work take of the dizzy cap clen up the connections in there. then try it should be ok after that
Old Mar 5, 2006 | 08:13 AM
wrcwrc's Avatar
wrcwrc
i had exactly the same symptoms as you've describved above.
would idle and run, but wouldnt drive and would backfire/cut out etc.
turned out my fuel gauge was inacurate and it was just the fuel getting low lol if your fuel is low i'd chuck some in it just to see
if not i'd look at your recently changed pump...... for leaks etc connections come apart etc?
cheers.
Old Mar 5, 2006 | 01:24 PM
j65_xss's Avatar
j65_xss
escort cosworth is nearly
Default awrite
i would check your metering unit i have had the same thing happen to me and changed that an it was fine.
Old Mar 5, 2006 | 01:43 PM
kitchcav's Avatar
kitchcav
this is what mine started doing yesterday i need help fuel pump play up aswell i think
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
