just finished making me garage a bit more theif proof
yep you need a "bash box" over the padlocks, also the angle bolted to the wall-have you used the masonry bolts with nuts on-if so you need to tack weld the nuts to bolt to save little scrotes undoing them!
hth
Tricky
hth
Tricky
cheers for all the input
they have to find the garage first as its no where near my house
Originally Posted by AdsCapri2
and dont post pictures of it on the internet theives will just analyse and evaluate how easy to get in!!
I suppose btu a row of old green garages in bristol area, wouldnt be surprised if people may recognise them
Originally Posted by Jamz
If they undo the 2 nuts on each side the whole lot looks like it'll fall off (assuming they are nuts).
Originally Posted by warrenpenalver
Liquid Nitrogen on the padlocks and a sledge should do it!!
that seems a bit extreme to me seeing as they dont know whats in the garage
Originally Posted by peters500
any local-ish kids hang about round there?
they are always too willing to put super glue in padlocks
[quote="fatboyz"]id like to see the little sh*ts get in to it now
pics not great only off me phone
from the state of the wood i would say one good kick and the wood is a gonna any way.
mate you should have put it on the inside. my garage looks identicle from the outside so as to not draw any attention but just behind the door i have security posts concreted into the floor and just to make sure i put in 3!!! so they may get in should i be unlucky enough to have my garage picked on but the car aint comin out!!!!!!
still saying that its better than nothing mate
crow bar/prybar behind that nice steel angle iron and its off. Wood is more rotten than gary glitters mind. Also 3 minutes on the roof and anyone is in!!!
As mentioned before, dont go posting your security measures on the net as someone will always reconise it........
Also if you know the scrotes have visited before, move garage. They will be back, more so now it looks like that.
This is not a dig, just wouldn't like you to loose anything valuable.
Don't ask - I don't know
better than nothing though!
I know about having garages broken in to.. little pykey theiving c*nts!
I have fitted a cemented in security post, lower cemented in door lock, full wireless alarm system and CCTV to my garage and floodlights
Looks like fort knox.. sounds like fort knox when it all goes off
No fucker has been near it*.. no fucker can get in*.. I have peice of mind and can sleep at night
so yes! anything is better than nothing
*touches wood
*touches wood
No fucker has been near it*.. no fucker could get in*.. I have peice of mind and can sleep at night
*touches wood
*touches wood
*touches wood
*touches wood
Is that all on a garage in a block in the middle of nowhere?
Cause its different if they are on your driveway for ten mins cutting it all open.
I'm liking that ALOT !!!
*touches wood
*touches wood
I would NEVER use a lone garage miles away
JoeyBoyden
Jan 4, 2024 02:36 PM
TrevCos
Aug 22, 2015 06:05 PM
borboyous
Aug 22, 2015 11:17 AM
