beds track pics
only a few as ant didnt take to many as the camera was to slow
i knew i should have taken the cannon 350d
well here are the results
hope you like sorry about the quallity cheers dunc
i knew i should have taken the cannon 350dwell here are the results
Originally Posted by Lambchop
porkie was on in the skyline? How did that go then?
straight line speed? mother ship?
how many cushions did you need? you'd have been dwarved in there
on the very first session battling with the M3CSL which was wickedly fast
Also the water temp was showing 115c after 2 laps! SHONKY DATSUN
I was only out in the afternoon as Renton only turned up in it at 2pm!
shame you did the diff in
whats the bhp again? how does it compare straight line against the sierra? does the weight hold it back a bit? what will it top out at?
fantastic car
It is a big heavy car and it sounded awesome, but didn't feel that fast in a straight line either. It's also disconcerting when you can feel the transmission shunting the power round, as you're not sure what it's going to do. I did drive it very conservatively through the corners though and had to slow down after each hard lap to get the water temps back down
. It later transpires that it is a common problem with the sender for the display and nothing wrong with the car
Didn't feel fast at all actually. It was spluttering and misfiring on 1.2 bar so it was only on low boost when Mike drove it. So its got a few problems to be honest right now as it was FAST when I first got it....
It was awesome though the bends though
Gutted about the centre diff though! that is going to be a HORRIFIC amount of money
Nice pics.
Lee - skyline does look good though. Shame about the diff.
How gutted am I that I couldn't make this one - I love Bedford, but what was with the coned off bit, and not using the start finish straight and the first two corners?
They had done some repairs to the side of the track (summit to do with the drainage) and the concrete hadn't gone hard due to the cold weather so to be safe they cut that section off...
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
chris m1
Sep 7, 2015 08:02 PM
Top one`s meeeee!!
