200 block kidney box thingy to 2wd sump
Old Feb 26, 2006 | 10:39 PM
fatboyz's Avatar
fatboyz
Default 200 block kidney box thingy to 2wd sump
i have finally got me 2wd oil pump and pickup and sump to go on my 200 block BUT the 4wd sump had a pipe that went up to the bottom of the kidney box what do i do with this now as the 2wd sump has nothing ???
also the sensor that bolted on the front end of the sump doesnt fit now either its far to close to the pully any ideas ??
cheers
ahhhh god damm 200 block to rwd its doing my head in
Old Feb 27, 2006 | 09:23 AM
SPADGE's Avatar
SPADGE
Block the pipe off
Can't see why the crank sensor won't fit though unless your missing a bracket
Old Feb 27, 2006 | 10:22 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
use a 2wd kidney box and 2wd crank sensor bracket,
Old Feb 27, 2006 | 03:17 PM
fatboyz's Avatar
fatboyz
cool cheers guys anyone got a 2wd kidney box and crank sensor bracket
ps i got the 4wd bits if anyone wants to trade
Old Feb 27, 2006 | 03:26 PM
St3V3_C's Avatar
St3V3_C
Phone Dan!!
Old Feb 27, 2006 | 03:28 PM
scruffythefirst's Avatar
scruffythefirst
4wd crank pulley is bigger than the 2wd one which caused me some ball ache with getting the crank sensor to fit. Ended up chopping another crank sensor bracket up and spacing it out. it looks to me as if the 4wd sump has a different offset of the studs that hold the bracket.
might be crap mind
Old Feb 27, 2006 | 03:57 PM
fatboyz's Avatar
fatboyz
out of intrest anybody know what i need to do for a power steering pump as the 2wd and 4wd are on different sides and the belts are different 2wd is the old style normal belt but the engine i have is the multi rib belt thingy
i was thinking of maybe fitting a 4wd steering rack and then using the 4wd belt and pump setup ?
Old Feb 27, 2006 | 05:10 PM
Micky The Finn
Former Sponsor
ive all the bits you need here,as for the pump, all you need is a 2wd set up which again ive got here,
Old Feb 27, 2006 | 05:11 PM
Micky The Finn
Former Sponsor
oh and you carnt put a 4x4 rack in if useing a 2wd crossmember.
Old Feb 27, 2006 | 09:31 PM
fatboyz's Avatar
fatboyz
damm only an idea , cheers for all your help mate do i have to use all the old style 2wd belts/pullys then ?? i have a 2wd pump still in the car but no bracket
how much would you want for the bits , if i change the pulleys then my crank sensor should fit ok yea??
cheers again mate
James Porter
Oct 28, 2015 12:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
lockie
Jul 31, 2015 10:03 PM
