Which headgasket?
Think i have just blown my headgasket, i new it was going to happen but which type do you recommend that i fit? there seems to be so many different types.the car is running stage 3 just after something that will hold the boost and hopefully be reliable, thanks.
You need to be carefull if its a triple layer gasket, if the block and head are not perfect the gasket will fail, the head is easy to sort with a skim, but the block? major work. ive been told to only use them on new blocks, as the gasket cannot absorb any imperfections in the surface.
I got mine from www.topendperformance.com
Also got a set of forged pistons there and an ARP head stud set.
Prices are a lot better then here in Europe, even including S&H.
220TC
13
Oct 25, 2004 11:22 PM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
