are all cvh efi heads the same?
im in the middle of rebuilding my fiesta turbo and hav noticed that a previous owner has converted an esc turb head for it. im not too keen on this.
ive got a head off an efi orion in stock. are they the same as the fiesta 1's?
Originally Posted by Rick
yes they are. Nothing wrong with using the escort head either.
EFI heads came with the injector cut outs on the inlet valves, MFI heads didn't have these!
the esc head that was on my car had been modified. They build up round the inlet ports with weld then machined out the holes for the injectors. Wasn't done very well tho, the gasket had very little surface area to seal onto. And to me werent cut out enough!
This is the problem with buying an already "modified" car. You just dont know what it actually is
The question that was originally asked here is: Is an Orion 89/90 spec normally aspirated EFI head the same as FRST EFI head. The answer is YES
No they're not! They've come with a different height. Orion EFI should be a little bit higher than FRST head, so you'll get lower compression which is better for higher boost
But make sure ignition and cam timing is set to the right parameters!
Sorry mate but your wrong
The lower compression on the turbos is achieved with different pistons
The lower compression on the turbos is achieved with different pistonsBut it's right that lower compression on turbos came from lower pistons, I didn't ever say something else!
mk3ste
Oct 17, 2021 10:09 AM
Mc5506
Oct 5, 2015 09:57 PM
