how do you undo the??
Old Feb 26, 2006 | 12:09 PM
gibbo frst's Avatar
gibbo frst
Default how do you undo the??
rear hub nut on a saff.. 41 mm nut . the rear arms are off the car i no i should have tried whilst still on the car. i used a thick extension bar through one of the holes in the hub to lock it which started to bend then snapped a 1/2 inch ratchet and it didnt budge at all.. tried heating it up but still no good.. any ideas or is it a job for a machine shop...????? cheers
Old Feb 26, 2006 | 12:12 PM
The DIVA's Avatar
The DIVA
Don`t forget mate,one of em is left hand thread so you will need to undo it clockwise...
Old Feb 26, 2006 | 01:46 PM
gibbo frst's Avatar
gibbo frst
shit.. didnt even look... bet the one i tried was goin the wrong way... never mind it can wait till next week now.. cheers
Old Feb 26, 2006 | 04:18 PM
CosKev3's Avatar
CosKev3
I've got the perfect tool for this
As long as you can weld,or get someone to weld for you?
All you need is an old brake disc off a sierra,and 3 foot of scaffold bar
Cut a slit in the end of the scaffold bar thick enough for the disc to fit in,then weld the bar to the disc
Easy one man job then to undo/tighten hub nuts
Will take a pic 2moro of it
Old Feb 26, 2006 | 04:53 PM
xr4x4rs's Avatar
xr4x4rs
even easier is put the car on the floor with original wheels on
as they have a hole big enough for a socket to undo the hub nut
handbrake on, in gera etc
41 mm socket and a big scaffold bar
right hand side is undo anticlockwise
left hand side is undo clockwise ( left hand thread)
ive just stripped my beam down 5 mins ago
Old Feb 26, 2006 | 04:56 PM
_DAN_'s Avatar
_DAN_
Yoon
Old Feb 26, 2006 | 07:59 PM
CosKev3's Avatar
CosKev3
Thats ok if the beam is on car,he said in first post beam/arms are off
Old Feb 26, 2006 | 08:03 PM
ballin's Avatar
ballin
need an impact gun really!
Old Feb 26, 2006 | 08:04 PM
xr4x4rs's Avatar
xr4x4rs
the its gona be a struggle but my beam was on the floor though
but i did have a electric impact gun aswell though
just need to find a strong bar to but through the hub then so it doesnt turn
then your socket and scaffold bar if u have a vice but the arm in the vics so its more sturdy
Old Feb 27, 2006 | 06:46 PM
CosKev3's Avatar
CosKev3
Heres what I had made:
Easy job then,with either beam on or off car
Old Feb 27, 2006 | 07:02 PM
xr4x4rs's Avatar
xr4x4rs
now thats a good idea
looks like an old brake disc with a bar welded on
im gona make something like that this week if it is
Old Feb 27, 2006 | 07:47 PM
CosKev3's Avatar
CosKev3
Read my first post m8
Thats all it is
Old Feb 27, 2006 | 07:50 PM
SPADGE's Avatar
SPADGE
No shit Sherlock
Si B
Sep 12, 2015 06:49 AM
Die-Cast
Fiesta RS1800/RS Turbo
Feb 12, 2010 12:00 PM
turbo.jon
Feb 24, 2006 10:56 PM
Alan s1
May 21, 2005 10:03 PM
