mk5/mk6 escort advice on windows....
27-02-2006, 04:34 PM
hi im new!!!
some little **** has smashed a few windows on my car
its a 98 escort 5 door.
are the rear quarter glass windows the same on a 94 escort?
is the windscreen the same?
also are these bonded in?
niiice. ty
27-02-2006, 04:35 PM
windscreen is the same (heated?) and bonded
Rear 1/4s prob the same too
27-02-2006, 04:36 PM
are the rears bonded too?
27-02-2006, 04:40 PM
on a 5 door dunno maybe, if they are broken you will be able to tell as there will be glass still attatched to the car
a 3 door no
27-02-2006, 04:42 PM
hmmm not quite, i think old astra ones are boned to a frame then BOLTED to the car so glass is attached still....
just thought id ask before removing trims to look
27-02-2006, 04:44 PM
well either way if its broken you will be able to tell before stripping it ... but its up to you
mk2 astra rear 1/4 windows are bonded in
27-02-2006, 07:50 PM
Baby Cheesus
mk5/6 rear 1/4s are bonded in, even trying to remove the rubber trim bit shatters the glass so i found out
ive got all door glass bar the drivers front door left and the drivers side rear 1/4
no windscreen tho
where abouts are you from mate?
Vincereese
01-06-2023 09:14 AM
FlashRS
14-09-2015 12:36 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
bonded ,
escort ,
ford ,
glass ,
mk5 ,
nk6 ,
quarter ,
remove ,
window ,
windows ,
windscreen
