Maximum Turbo Boost??
Old Feb 25, 2006 | 06:59 PM
Cosworth-PT's Avatar
Cosworth-PT
Default Maximum Turbo Boost??
My sapphire is making 18PSI peak and then drops to 15PSI. Is this too much?
Is stage 1 with standard injectors. I know that 15 PSI is max recomendend for stage 1 but don't know if it's peak or constant boost here.
thanks in advance for any advice
Old Feb 25, 2006 | 07:16 PM
grunter's Avatar
grunter
thats wot mine peaks at 2 mate mines a stage one and its been running fine like it
Old Feb 25, 2006 | 08:42 PM
Finny's Avatar
Finny
same with mine too. stg 1 and all that, peaks at 18, drops to 16 and holds that. so no prob there mate.
Old Feb 25, 2006 | 09:38 PM
grunter's Avatar
grunter
just out of curiosity wot chips do u 2 have????? mines a pathetic superchip thats being changed asap
Old Feb 25, 2006 | 09:43 PM
KSA-Cossie's Avatar
KSA-Cossie
Just make sure the fuelling is ok .
Old Feb 25, 2006 | 11:38 PM
Cosworth-PT
Chip is a Collins.
I'm asking this because I have started to feel a strong vibration past 4000rpm, don't know if it has anything to do with turbo. l didn't notice before with 13 psi. something like having a engine mount broken or so (but checked mine and are fine).
Old Feb 26, 2006 | 09:57 AM
cossie604's Avatar
cossie604
Is it just revs or more like a fixed road speed? If its just revs, check your exhaust for fitment, ie sometimes if its not hung correctly and some part of it is stressed then it can cause a vibration/tizz also check your turbo damper...an item that gets over looked, mine included
Stu.
Old Feb 26, 2006 | 10:12 AM
Cosworth-PT
Had a look and something is wrong with turbo dumper. going to take a picture and post it here in some minutes
Old Feb 26, 2006 | 10:36 AM
Cosworth-PT
Spring is compressed a lot and there is a big gap also. Don't know if this is correct.
Old Feb 26, 2006 | 02:24 PM
Cosworth-PT
well, the vibration has to do with the gearbox for certain. now it's getting harder to shift... any ideia?
Old Feb 27, 2006 | 10:55 AM
foreigneRS's Avatar
foreigneRS
Testing the future
turbo damper looks quite normal, but hard to say from those pictures. i have the section of workshop manual that tells you how to adjust it correctly if you would like it?
Old Feb 27, 2006 | 11:20 AM
Jimbo's Cossie's Avatar
Jimbo's Cossie
Had alot of vibrations throuh the gear stick at 2500-4000 rpm but got my self a bailey turbo damper. it feel like im chaning gear with the engine off now in comparson to how it was getting before.
Defontaly a worth while mod in my opinion and looks the business
Old Mar 5, 2006 | 11:04 AM
Cosworth-PT
Thanks, I have the workshop manual, they say 4mm between supporter and damper, but I have a lot more, spring doesn't look too good.
I think I will get a new damper kit. Anyway I have ordered new engine mounts also. I'm getting crazy with this.
Old Mar 5, 2006 | 11:06 AM
Cosworth-PT
Mine starts vibrating like hell around 3000 (as soon as I get positive pressure) and never ends till I decelerate. If I acelerate gradually without puting too much pressure, vibrates but not much.
I believe it has something to do with damper or engine mounts.
Old Mar 6, 2006 | 12:29 AM
paconassa's Avatar
paconassa
isso parece-me detonação (mistura pobre dá combustão anormal)...
nao sera isso?
boa sorte!!!
Old Mar 6, 2006 | 04:27 PM
Cosworth-PT
as paconassa said: probably detonation
checked sparkplugs and are all f**ked with no poles at all
already ordered new 071's, was using 901s
I was able to buy a new turbo damper kit (original one and the last in Portugal ) (99 Euros + vat) ouch!
Old Mar 7, 2006 | 10:37 PM
Cosworth-PT
new plugs, still the same... I think I will need to remove the gearbox now, have nothing more to be done except for the new engine mounts....
Old Mar 10, 2006 | 09:30 PM
Cosworth-PT
Got the gearbox out today, replaced clutch kit with a used one just to test. Every vibration went off. evrything is fine now, however clutch is used and engine slips a lot.
anyone has a cheap one for me?
mgtkr1
107
Dec 6, 2016 04:23 PM
Matt Baxter
Sep 16, 2015 08:30 PM
gchristophi
Aug 31, 2015 10:36 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
Escortdriver1
Jul 31, 2015 02:36 PM
