TPS
Old Feb 23, 2006 | 02:05 PM
cossiegreg1's Avatar
cossiegreg1
Default TPS
can i have an idiots guide on how to adjust the throttle position sensor on my 2wd sapphire cosworth please
Old Feb 23, 2006 | 02:10 PM
keithG666's Avatar
keithG666
Old Feb 23, 2006 | 02:13 PM
Spiky's Avatar
Spiky
can i ask why you wanna change it
and
keithG666
the screw drvier needed to change it while on the car needs to be VER small, i.e. not long like those
Old Feb 23, 2006 | 02:28 PM
keithG666's Avatar
keithG666
picky tosser!!!
its because he wants good pops on the overrun!!!
cossiegreg1
i want to check to see if its correct
Old Feb 23, 2006 | 02:32 PM
Spiky's Avatar
Spiky
keithG666
correct size, flat one only needed
cossiegreg1
it needs to be set ti something link 3%
but unless you got a secs or pectel monitor you aint gonna know it is set right,
Old Feb 23, 2006 | 02:40 PM
cossiegreg1
well the problem is that my car ticks over at 3000 rpm unless the iscv is disconnected.i have tried another iscv in and it made no difference.so some one told me to adjust TPS and im asking how to do it.
Old Feb 23, 2006 | 03:44 PM
jon@work's Avatar
jon@work
Are you sure that the outer two TPS wires are the correct way round ? (A friend of mine fitted a PF09 and L8 to his car and changed the wires round, forgetting that I'd already changed them round, so his car would sometimes idle at about 3k)
Old Feb 23, 2006 | 05:26 PM
davidreader5's Avatar
davidreader5
cossiegreg1,
Hi,
for 2wd switch pfo1,
Resistance check for switch, ignition off, throttle closed pin +11, & -30, 400 to 600,ohm's
pin +30 pin -17,throttle @ idle position 00, slowly open throttle to fully open, observe multimeter, around 40 to 150,ohm's with the throttle just open, to full resistance, with wot, approx 300 to 600, ohms,
there are other ways of doing the above check using different pins of the
ecu plug, ALSO as the map sensor is on the same lines disconnect when checking.
Volts for T/Switch, pin +30,& pin - 11,ignition on throttle closed 4.5 to 5.5volts,
throttle fully open approx 0.5 to 0.6volts. as above checks can be done @ different pins adjust switch to suite,
these checks are from ford workshop manual.
Dave R.
DixieTheKid
11
Jun 6, 2020 11:20 AM
muffster
13
Sep 3, 2015 09:40 PM
cozzy jeff
Aug 31, 2015 04:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Roosie
Aug 15, 2015 08:09 PM
