rs turbo mfi xr3i mfi do they have the same fuel pump
Old Feb 23, 2006 | 12:14 AM
ford crazy's Avatar
ford crazy
Default rs turbo mfi xr3i mfi do they have the same fuel pump
nearly got car ready for mot
been a long haul can see the finnish line ahead
and fuel pump starts to wine
is it me or are these rs turbos jinksed
been one thing after another
any way i have a fuel pump for a mk4 xr3i mfi
are they the same as the mk4 rs turbo
thanks
Old Feb 23, 2006 | 01:18 AM
DannyDK's Avatar
DannyDK
Yup, its the same, i have seen in Denmark lots of part supliers having it with the exact same part number, so it must be the same by 99%
Old Feb 23, 2006 | 10:23 AM
ivorbiggun's Avatar
ivorbiggun
It depends, some of the XR's/injected Orions had a different sized fitting
with a smaller banjo on the end of the fuel pipe. You can still connect the larger RS banjo to the pump but almost invariably there will be a small air
leak, which will mean it's a bitch to start and even when you do get it going
the ingress of air into the system means that 30 mins after you turn it off
re starting is VERY difficult. With any luck you'll be OK/if the outside diameter
of your pump output is 11.75 mm you're fine if it's smaller welcome to my club.........
Old Feb 23, 2006 | 11:24 AM
JesseT's Avatar
JesseT
I'm quite sure the S1 and XR3i had the same pumps and the S2 a bit more powerful version.
Old Feb 23, 2006 | 04:32 PM
DannyDK's Avatar
DannyDK
I have/had the same pump in both my s2 and my mk.4 xr3i
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
