Newman cam......
Old Feb 21, 2006 | 05:51 PM
rstdave's Avatar
rstdave
Default Newman cam......
After havin some trouble with Kent cams, thinkin about gettin a Newman cam after hearin good things about em! My question is, do they come in different specs??? If so, what options are available??? I haven't seen em advertised anywhere either, u have to get them direct???
Old Feb 21, 2006 | 07:44 PM
Rallyesport's Avatar
Rallyesport
Only one profile for turbo and you must use their mechanical lifters and double valve springs.
Old Feb 21, 2006 | 07:52 PM
T28 RST's Avatar
T28 RST
Ok then
I have one
Old Feb 21, 2006 | 09:09 PM
turbo.jon's Avatar
turbo.jon
How much does 1 cost????
Old Feb 21, 2006 | 09:20 PM
Davey8oy's Avatar
Davey8oy
mine come to 390 all in
cam
tappets
and there is a couple of different turbo cams availible
Old Feb 21, 2006 | 09:24 PM
G-Junior's Avatar
G-Junior
Ordered 1 yesterday Ł310 with solid lifters and delivered.
Check www.newman-cams.com its got the different cam specs on there.
Old Feb 21, 2006 | 10:04 PM
rstdave's Avatar
rstdave
Cheers for the replies....gonna get on the phone to em tomoro and get one ordered up! Hope it lasts longer than the 2 Kent pieces of shit i've had in there!!!
Old Feb 21, 2006 | 10:17 PM
T28 RST's Avatar
T28 RST
Ok then
Ive had mine for 3 years now and ive not had any trouble
Old Feb 22, 2006 | 06:24 AM
Rallyesport
cam
tappets
Only one suitable for 1.6l.
Old Feb 22, 2006 | 08:42 AM
ivorbiggun's Avatar
ivorbiggun
If you've had two 'shit' cams, probably a good idea to find what caused them
to wear out before dropping another in there.
Old Feb 22, 2006 | 11:42 AM
Rallyesport
If your oil pressure is low because of a worn bottom end your head will receive less oil and you really would like to have the head lubricated well.
Old Feb 22, 2006 | 11:58 AM
Rallyesport
Should be read by everybody.
CAM WEAR PROBLEMS
I alluded briefly to the CVH cam wear problem in the introduction. As this crops up so often on newsgroups and emails I'll expand on the matter. The CVH cam is lubricated by the oil that drips through little brass bushes next to the rockers. Even this limited supply can disappear if the bushes clog with carbon due to infrequent oil changes and cheap oil. Also the valve spring is extremely stiff compared to other engine designs. It generates a load at full lift of 220 lbs compared say to 125 lbs for a Pinto or Mini engine, 150 lbs for an MGB. This high spring load is necessary to control the heavy rocker and lifter and still only allows about 6,700 rpm before valve float starts. To compound the matter, Ford didn't use the best available material for the camshafts. "Chill cast" camshafts last several times longer than the induction hardened material used in the CVH.
Cam wear is therefore a fact of life with the CVH. Most other types of engine show little or no cam wear in normal use and if wear does start then it tends to accelerate exponentially leading to rapid failure. Standard CVH cams wear steadily from the moment they are fitted. I've never stripped a medium mileage road CVH engine that didn't have considerable wear on the lobes and lifters. The problem is worst on cylinder 4 next to the fuel pump lobe. This is nothing to do with the urban myth about cylinder 4 being furthest from the oil pump. Whoever started that one wasn't the world's deepest thinker. The oil supply runs up through the block between cylinders 2 & 3 so in fact cylinder 1 is as far from the pump as cylinder 4 despite being right above it. In fact there is a design fault in the engine which means that the cam lobes on number 4 are not properly positioned relative to the lifter bores.
Cam wear starts to take place about half way up the lobe. It then leads to dishing of the lifter base and loss of material over the cam nose. As the lifters dish, a sharp lip is created round the base of the lifter which means they often won't withdraw through the lifter bore. If this occurs then under no circumstances try to graunch the old lifters out with a pair of pliers. You'll score the lifter bores and ruin the oil pressure to the lifters. Raise the lifters until they are clear of the cam lobes, remove the cam and then push the lifters into the head and get them out through the distributor housing bore. Check every lifter bore for wear. On neglected engines the bores can wear and this means the head is scrap. Take a lifter and turn it upside down so you aren't inserting the lip into the bore - better still use a new lifter if you have one. It should just slide into the bore with no appreciable rock. Copyright David Baker and Puma Race Engines
There is NO, I repeat NO point in fitting new lifters to an old cam in the hope of fixing a noisy engine. The new lifters will be reduced to scrap by the worn cam lobes within minutes of starting the engine. Replace everything, clean the brass lubrication bushes and if the head is really badly clagged up (which they tend to be) then remove the head and have it chemically cleaned to remove all carbon deposits from the oilways. Then fit and run the new cam and lifters in properly - use plenty of cam lube on the lobes and lifter bases and don't let the engine idle for the first 15/20 minutes - keep the revs at around 2000 which gives the cam a chance to bed in and work harden. Change the oil and filter too (flush the engine out as well if you want to do the job properly) - all that material that wore off the old cam lobes is down in the sump gradually wrecking the crank bearings and oil pump.
Fix a worn cam problem properly and you'll get as good a life out of the new one as you did from the original. Get it wrong, leave the oilways blocked, fail to use cam lube or run in properly and you'll be doing the job for a second time within weeks.
http://www.pumaracing.co.uk/cvh.htm
Old Feb 22, 2006 | 01:59 PM
ON-UJAH's Avatar
ON-UJAH
When it comes to the CVH head, Dave knows his stuff!
My experience is that No.1 exhust tappet will go first, possibly due to poor castings in the oil feed. Worth a look if you are reconditioning a head.
Old Feb 22, 2006 | 05:57 PM
rstdave's Avatar
rstdave
I know what you'r sayin....i will be makin sure there's nothin untoward causin it...but it's a fully rebuilt engine usin all new parts, with the head bein ported/polished, new oil pump etc. I've also got an oil pressure gauge which shows the oil pressure to be fine! Anythin in particular u think could be causin it??? Alot of people have bin havin problems with kent/piper cams, which the guy from newman seemed to know about without me promptin him!
Christian and Beccy
11
Oct 19, 2021 03:14 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
motherhupit
Feb 25, 2008 02:43 PM
GraphiteGray
Sep 21, 2007 04:24 PM
