Top Result MSD Does it again !!
Old Feb 20, 2006 | 03:49 PM
AlexD's Avatar
AlexD
Post Miester !
Default Top Result MSD Does it again !!
I decided last week to fit a MSD Closed loop chip to the Escos, well after
having to cut out the big wiring plugs and several other little niggles, Stu
had the chip and -31 delivered to my door in his usual quick time, and i am
now sporting a MSD sunstrip too
We fitted the New Chip and -31, then we testing on our own local "private
duel carrigeway.
After sort this, i decided to go with a mate to get his evo on the rollers for a power run, which we also booked in the cossie..
And sure enuff the setup was correct 359.7 BHP
And on the way up and back was averaging 30-34 Mpg...
Thanks Stu............
Al............
Old Feb 20, 2006 | 03:51 PM
KSA-Cossie's Avatar
KSA-Cossie
Top work fellas.
PaulCossie's Avatar
PaulCossie
nice.... think im gonna go closed loop on greys when the car is finished
Old Feb 20, 2006 | 03:52 PM
Sean_RS's Avatar
Sean_RS
result
Old Feb 20, 2006 | 04:08 PM
martrs's Avatar
martrs
Nice one
Old Feb 20, 2006 | 04:12 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
34mpg and 359bhp? AWESOME!
well done Stu!
chop
Old Feb 20, 2006 | 04:40 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Fantatic result. Well done Stu
Old Feb 20, 2006 | 05:48 PM
rapidcossie's Avatar
rapidcossie
so how many miles do roughly get for a full tank of petrol??
Old Feb 20, 2006 | 06:00 PM
B11GNS's Avatar
B11GNS
Its the only way to go mate
Well done stu
What injectors gave you that power mate?
Old Feb 20, 2006 | 06:05 PM
AlexD's Avatar
AlexD
Post Miester !
I am still on greens and there is plenty of fuel throughout...
I just has run in with a Porsche Carrea, lol... The words " should have got
one of these came to mind ..lol............
Al.............
Old Feb 20, 2006 | 06:07 PM
B11GNS's Avatar
B11GNS
Al.............
Very good for greens
Old Feb 20, 2006 | 06:15 PM
AlexD's Avatar
AlexD
Post Miester !
Yes it is, i am well impressed, need to get a RS 500 Cooler Now....
The car drives soo much better now, much more ususable power..
Al.............
Old Feb 20, 2006 | 07:18 PM
Sticky.'s Avatar
Sticky.
Another happy customer
Old Feb 20, 2006 | 08:42 PM
gurnE's Avatar
gurnE
Good work, shame I couldn't come up today.
Now lets get the proper cossie fixed
Old Feb 20, 2006 | 09:38 PM
Greg Shepherd's Avatar
Greg Shepherd
Chasing Radders
if i ever get a cossie i know whwere it going for
good result nice one stu
Old Feb 21, 2006 | 08:08 AM
maxest's Avatar
maxest
Old Feb 21, 2006 | 03:01 PM
Stu @ M Developments's Avatar
PassionFords Creator
Im pleased your enjoying the conversion Alex. Thanks for your Business.
Old Feb 21, 2006 | 03:46 PM
Beach's Avatar
Beach
Were so lucky to have so many tuners with spot on knowledge
Well done Stu
Old Feb 22, 2006 | 08:34 AM
Your all spoilt
Old Feb 22, 2006 | 10:00 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
i want one!!!!!!!
Old Feb 22, 2006 | 10:06 AM
Sticky.'s Avatar
Sticky.
Originally Posted by JTECHSAFF
i want one!!!!!!!
Get your money out mate & get your car booked in. You have to spend money to save money
Best conversion ive done to the car so far
Old Feb 22, 2006 | 10:09 AM
JTECH James
Passion for Fords!
they do the stage 3 kit as a diy dont they? devon is miles away!!! itl cost me Ł100 quid to get there but only Ł10 to get home
Im just running it in then its a must!
Old Feb 22, 2006 | 10:20 AM
!mouse-oxford!'s Avatar
!mouse-oxford!
Old Feb 22, 2006 | 12:14 PM
Kevin B's Avatar
Kevin B
Sorry to go slightly off topic, but...
Just a quick question regarding removing the large plugs at rear of engine - is it just a case of cutting them out and joining the wires (soldering) or is there more to it?
I ask because I am having to pull them apart, wd40/clean them and put them back together every month to cure an annoying misfire/jumpy rev counter Also think it tidies the bay up nicely too
I remember the pics of RS Gus's old Saph when he had done this, but I never asked how he did it??
Many thanks in advance
Kev
Old Feb 22, 2006 | 12:22 PM
Yes.
P.S: WD40 will make it worse, junk shouldnt be allowed near electrical systems.
Old Feb 22, 2006 | 12:44 PM
Kevin B's Avatar
Kevin B
Thanks Stu - much appreciated
Old Feb 22, 2006 | 01:39 PM
gingeRS's Avatar
gingeRS
so whats the deal with closed loop?
how does it work, and how is it different to my stage 3 4x4 running a PE chip?
if mines a 1992 model, does that mean it has a cat? is this neccesary for closed loop
any info appreciated
rory
Old Feb 22, 2006 | 07:52 PM
This will go some way to explain:
http://www.motorsport-developments.c...closedloop.htm
Old Feb 22, 2006 | 09:00 PM
AlexD's Avatar
AlexD
Post Miester !
Kev
This was done on my escos simply by cutting the plug each side one by one,
soldering and then heat shrink,however do each one at a time as they are not
all the same as you may think..
Yes mine was bought as a kit and fitted myself, Once i was happy i took it to
for a RR session to check the fuelling,boost etc... Only soo much you can do
on a dual carrigeway :
Al............. D
Old Feb 23, 2006 | 08:47 AM
gingeRS's Avatar
gingeRS
Originally Posted by Stu @ M Developments
have read all that cheers stu
so as my car is green top 4x4, it has a lambda just behind the turbo
so what do i need for 30mpg, rather than 20
and can i fit it myself, or would it be worth the long trip to blackpool, as i have little experience with engine electronics
Old Feb 23, 2006 | 08:53 AM
Depends what power your interested in Ginge?
Up to around 350 (803s) i can send it across as a diy kit with instructions.
After that its live map only im afraid pal.
Old Feb 23, 2006 | 08:58 AM
gingeRS's Avatar
gingeRS
i am currently running 311bhp and thats enough for me for the minute
only had it a week.
its running a T3 and 803's so what would i need and whats involved with the kit
Old Feb 23, 2006 | 09:32 AM
On a late spec car all the work is done for you, i simply need to send you a chip and a hardware key, you plug it in, make a few tweaks as per the instructions and your all done. Ł250 plus P&P
The ONLY limitation is it must be a totally STANDARD ecu that still has its original daughterboard. Pectel hardware is a no go.
Old Feb 23, 2006 | 11:25 AM
gingeRS's Avatar
gingeRS
dunno if it has a standard ecu?
was stage 3'd in december 05, by power engineering with a receipt for 'stage 3 chip' Ł120?
as i dont use the car much, is it possible to send you my ecu? or are there other parts that need modifying?
does this cure the random idling, (ie 1500 rpm on a cold start) associated with stage 3 cars? or is this just my car and likely to have another cause?
Old Feb 23, 2006 | 11:29 AM
AlexD's Avatar
AlexD
Post Miester !
That might be the cacky idle control valve sticking, mine does it from time to
time, that and i had a crap collins dump valve on it that was leaking !!
Al...........
Old Feb 23, 2006 | 11:33 AM
Hi, At Ł120 its unlikely you have a Pectel conversion so you should be ok.
Yes, you can send me the ecu and i will make the modifications to teh daughterboard and fit the chip FOC and post it back to you before 1pm next day, all you should have to do then is plug it in and go, although i do advise you have the system given teh once over by a pro with a fuel monitor who can set your boost and check teh fuelling is ok.
All Cosworths should idle, AND drive, teh same cold as they are hot.
Its worth noting a raised idle of between 1200 and 1400 rpm is normal on a cold YB until it gets some heat into it to allow a steady idle.
Old Feb 23, 2006 | 11:34 AM
Sticky.'s Avatar
Sticky.
Mine has started to that, nothing to do with the closed loop, on inspection we noticed the IISC was not closing properly & have been advised to get a new one.
Old Feb 23, 2006 | 11:44 AM
trotty's Avatar
trotty
hi stu,
i have a 1994 small turbo escos which i'm very interested in putting closed loop on.
all it has is a stage 1 tune with stainless exhaust, k+n induction kit, and superchip.
can you tell me what it would cost for the diy kit, and fitted with set up?
cheeRS.
Old Feb 23, 2006 | 11:45 AM
gingeRS's Avatar
gingeRS
Al...........
are these the same thing?
from ford? or second hand?
Old Feb 23, 2006 | 11:49 AM
trotty's Avatar
trotty
alex, just out of interest, what rolling road do you use to get yours set up?
i'm not too far away from you and i'm after a good local tuner.
