wheres all the fuel going ???
Old Feb 20, 2006 | 11:39 AM
3dr_Mark's Avatar
3dr_Mark
Default wheres all the fuel going ???
HELP .......
I have not long bought a R plate escort ghia estate 1.8 Zetec, which has only covered 53000 miles.
Ive had the car looked at as its using lots of fuel, im getting about 22.mpg which was 220 miles to a full tank costing me £40 (ouch), this i feel is a little excesive for this kind af car
Can anyone help me to sort this out by previous experences
I would appriciate all the help i can get as im doing about 300 miles a week and at this rate it will be easier to scrap it
Thank you
Mark
Old Feb 20, 2006 | 11:42 AM
R4N SS's Avatar
R4N SS
not sure but my mondy turd diesel drinks a lot too
Old Feb 20, 2006 | 11:48 AM
Spiky's Avatar
Spiky
my mondeo was 1.8 zetec and on a run it would get something like 400-450 off 50 quid
around town (with exhuast blowing it would get 300ish to 50 quid.
the lotus is 1.8 and gets 300ish to 31quid
and thats flat out and going back and forth work
so my advice sell the escort and get a lotus
Old Feb 20, 2006 | 01:04 PM
Jonzy's Avatar
Jonzy
My cupra 20vt drinks about the same 200 miles to £40 So much for an economical family car
Old Feb 20, 2006 | 01:26 PM
roybacer's Avatar
roybacer
Exactly the same with my old Leon Cupra, was fucking aweful
172's averaging about 32mpg
You sure you escort does not have n e fuel leaks ????
Old Feb 20, 2006 | 01:50 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i would suggest that you interrogate the ecu for fault codes. your lambda sensor may be broken.
and take off those lead filled boots
Old Feb 20, 2006 | 06:17 PM
3dr_Mark's Avatar
3dr_Mark
Thanks for the advise guys
Ive also got a 1.8 turbo golf and that gets about 35ish mpg with some heavy foot driving,
I never bought the escort to be better on fuel, but i was realy suprised when it drank a full tank in 200 miles
so sounds like i deffo got a problem then......just a case of trying to find it
Old Feb 20, 2006 | 06:25 PM
filthyrichie's Avatar
filthyrichie
is it misfiring ...look at plugs and leads they always cause faults and cats are favo too
Old Feb 20, 2006 | 06:52 PM
3dr_Mark's Avatar
3dr_Mark
Dose not seem to be missfiring, altho it dose have a hicup evernow and then but its not offten at all.
i spose that could be a lead
If i have to describe how the car drives i would say it feels like its a lasy engine and i have to work it to make it go, sort of like its resisting, dose not want to rev, so im thinking now a cat has been mentioned that it could be somthing to do with that, are these engines normaly like this?
or am i too used to the free reving golf?
Old Feb 20, 2006 | 07:17 PM
GOT2BZETEC's Avatar
GOT2BZETEC
Good thread, i have a 1.6, mk6 hatch, and only do about 23mpg, i drive it reasonable hard, My exhuast is blowing a bit, will this make any diffeence, and power?
Old Feb 20, 2006 | 07:24 PM
nomiseel's Avatar
nomiseel
Hi i am new to all this forum stuff but here goes . A work colleague had a 1.6 estate and he said he anly got 27 mpg back and fore to work was a bit better on a run . I had a 1.6 festa si drivng it like miss daisey got 35 out of it . 2 mate at work have 1.8 gti and the one reckons he can get 35 out it but i am no sure on that one . Whats your driving style like . you say the engine is lazy . Are the filters new plugs clean new old , do they have the right gap your cat may be blocked . if your engine cant breath then you will use fuel i hope you sort it or your can by a diesel and run it on veggie oil like i do but thats another story ?
Old Feb 20, 2006 | 08:51 PM
filthyrichie
look at plugs...may have non ford in they hate that then cat i recon
Old Feb 20, 2006 | 10:15 PM
3dr_Mark's Avatar
3dr_Mark
Cheers guys
Tis a petrol 1.8 zetec, if it was a diesel i would be even more surprised
I will stick a set of genuine ford plugs in it at the weekend (or b4 if i get chance), do you recon it would be worth changing the leads as well?
If that dont seem to work i will see about removing or replacing the cat.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
