Turbo Heat
Old Dec 6, 2003 | 01:32 PM
Default Turbo Heat
I have a problem of excessive heat coming from my turbo,there is a constant smell of burning rubber too.the bottom of the turb also has a white powdery coating on it now. local ford garage was no help . I have a 92 4x4 sapphire. Thanks
Old Dec 22, 2003 | 03:13 PM
The problem here is fueling, the exhaust gasses are to hot, this means that you are running lean and it needs to be rolling roaded to get the fueling right, if you dont do this the say bye to your turbo and possibly your enginge as it will dettinate
Old Dec 22, 2003 | 09:25 PM
Phil's Avatar
Phil
Jeebus
do you have a turbo heat shield on???
the rubber smell is probably the protective layer around the clutch cable!!!
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
kevin36
Sep 2, 2015 06:24 PM
