rs startin prob
Old Feb 9, 2006 | 12:35 PM
davie0146's Avatar
davie0146
Default rs startin prob
Hey up peeps
Small prob with the RS, after many moons of the thing not starting I have finally managed to get it going only 1 problem though!
To start it I need to bridge the fuel relay and leave it going for about 30-60 seconds and then start it and then it starts with a bit of a struggle! Once started it is fine at idle and also when out on the road both on boost and off.
Once the car has been started I can then restart it without bridging the relay, but if I leave it for any time then I have to go through the bridging the relay route again?
If I try to start it without bridging the relay it will just turn over until the battery dies.
It has not been set up since I fitted the S2 metering head due to not being able to get it to the tuners. The fuel pump sounds ok no funny noises or anything like that.
On the front of the fuel pressure regulator there is a small length of 3-6mm vacuum tube which has been blanked off where is this meant to go?
Any hints, tips or idea cheers
yorkie92
27
Sep 22, 2017 05:56 PM
gcfcos
59
Oct 6, 2015 05:04 PM
gcfcos
88
Sep 15, 2015 03:48 PM
ray barker
Aug 7, 2015 09:00 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
