Dumpvalve & bleedvalve
Old Feb 9, 2006 | 01:37 AM
DannyDK's Avatar
DannyDK
Default Dumpvalve & bleedvalve
What is the difference on the two and what does a bleedvalve do by the way?
I know about the DV but not the BV
Old Feb 9, 2006 | 08:40 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
A Bleed Valve is one of the most basic forms of Boost Adjustment and generally costs around Ł15.
They are the cause of alot of failed engines, due to how easy it is wind the boost up and melt the engine.
They are quite good though if used correctly. The Alloy one's are a little unreliable though, due to the fact that they are affected by heat.
Old Feb 9, 2006 | 03:47 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
bleedvalve as above....
dumpvalve is a form of pressure release for turbo cars. has no practical use on a RS turbo unless running silly high boost. Forget them
Mr.Ford
Mar 4, 2005 10:57 PM
Mr.Ford
Feb 4, 2005 12:49 AM
Stavros
Jan 4, 2005 02:11 AM
JohanRS
15
Oct 13, 2004 08:42 PM
Mar 28, 2004 08:15 PM
