Fiesta ST This forum is for discussion of all things pertaining to the Ford Fiesta ST Range of cars.
fiesta st brake cable question
Old Oct 5, 2011 | 10:29 AM
Northants Ford Fan's Avatar
Northants Ford Fan
Default fiesta st brake cable question
Hi guys, im doing the st rear brake conversion on my girlfriends mk6 zs and was wondering if i need to change the whole hand brake cable over or just the end sections they have on the zs ? i dont have the st cable to see how they differ so want to check before buying the cable if i dont need it, ive tried using euro car parts to check part numbers and they come up with in the detail section the brakes are drums on the rear lol.
Old Oct 5, 2011 | 12:18 PM
martysmartie's Avatar
martysmartie
99.9% it will be the cable, ST is discs, ZS is drums and both will have different types of handbrake cables, if you look on top of the calipers you will almost certainly see a lever there, this is the handbrake mechanism.
Martin
Old Oct 5, 2011 | 12:34 PM
Northants Ford Fan
on the zs its a 3 piece cable the main bit fom the handbarke handle in the car to either side of the beem and two little connecting wires about 8 inches along that connect to the main cable then into the drum, I was just wondering if the st cable is one bit or 3 like the zs with different connecting sections ?
Old Oct 5, 2011 | 12:36 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
You need to use the ST cable.
Old Oct 5, 2011 | 12:37 PM
martysmartie
No drum cables go inside the drum itself and onto a "Handbrake lever" on the trailing shoe and have a nut on the end which hold them in place.
Calipers on the other hand have levers on the top usually and have different fixings on the two ends of the cable which sit over these levers to actuate them.
Martin
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 10, 2015 12:08 PM
Bosch
Aug 4, 2015 05:14 PM
