Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fiesta1.25 problem
Old Jan 9, 2013 | 06:38 AM
Fordmad!'s Avatar
Fordmad!
Default Fiesta1.25 problem
As above when cold it is hard to start and stalls. Its okay after a few minutes.
I was thinking plugs as we've only just had the car and im not sure when they were changed.
Anyother things i should check.....
Old Jan 9, 2013 | 06:51 AM
STeve's Avatar
Super Moderator
the cold start valve would be my first port of call
Old Jan 15, 2013 | 06:58 AM
Fordmad!'s Avatar
Fordmad!
Right the engine managment light has come on so ive changed the plugs and its go off and does run/start abit better.
Its still stalls when cold and sometimes when its warm aswell. You have to give it gas when your reversing etc or it stalls!
Thought of changing the cold start valve next as above but what else could it be??
Any ideas?
Old Jan 15, 2013 | 07:09 AM
There is normaly a idle speed control valve on the inlet manifold.Its held on by two 8mm bolts.Remove that and clean it out with some brake cleaner then use some wd40.(i use brake fluid on the cossies iscv) and try that.
Old Jan 15, 2013 | 07:14 AM
Fordmad!'s Avatar
Fordmad!
If it was the iscv wouldnt the revs be everywhere? It idles perfect, its just very sensitive when you go to move off when cold!
Old Jan 15, 2013 | 07:23 AM
the_frozen_one's Avatar
the_frozen_one
Depends how much gas you use to pull away. If you move off with not enough gas the ISCV opens to keep the engine running as it thinks the engine is stalling.
Old Jan 15, 2013 | 08:10 AM
Fordmad!'s Avatar
Fordmad!
I'll give that a clean first then and see how it goes!
Old Jan 15, 2013 | 09:49 AM
Brendan's Avatar
Brendan
struggling with reality
can you read the ECU ? I know they are early but can report faults to right daignositc reader.
Old Jan 15, 2013 | 11:15 AM
Fordmad!'s Avatar
Fordmad!
I think so that was my next move as i could be chasing problems for ages
Old Jan 15, 2013 | 08:51 PM
foreigneRS's Avatar
foreigneRS
Testing the future
MAF. try unplugging it and see how it does. if it runs better, then it's knackered (as the ecu reverts to a 'safe' value and 'overfuels' it which makes it run better.
Old Jan 15, 2013 | 09:19 PM
Cosnada's Avatar
Cosnada
Air leak - from a vac line etc?
Old Jan 16, 2013 | 06:45 AM
Fordmad!'s Avatar
Fordmad!
My mates got a diagnostics so he said he'll do it for Ł20 so i'll see what that throws up and go from there i think!!
Old Jan 16, 2013 | 11:42 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
There is a little rubber breather set up that sits underneath the ICV, quite hard to describe but has three rubber hoses that connect to each other then into the inlet manifold? I would take them off and check them thoroughly as I've had a few over the years that have split and caused the car to run like a bag of sh*te.
Old Jan 16, 2013 | 05:12 PM
Fordmad!'s Avatar
Fordmad!
Right okay cheers i will check them!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
