help needed please?
Old Dec 17, 2013 | 10:53 PM
mattxr2's Avatar
mattxr2
Default help needed please?
Hello everyone I have recently fitted an mfi rs turbo engine into my mk2 fiesta and converted it to efi using a 36-1 trigger wheel.. I have a 195 chip beige 701 injectors, adjustable fuel pressure regulator, 044 fuel pump, cosworth 3bar map sensor.. My problem is that the car is running realy rough like its missfiring and I put the car on a mot emissions tester and it was reading a co level of 12.50 iv been told this is very high? When driving the car it seems to boost but holds back there isn't realy any power there.. I changed the fuel pump, coil pack, plugs and leads to see if it would cure the sort of missfire.. It also seems to pop and bang a lot threw the exhaust when driving the car and it keeps cutting out on me, when I rev the car it just goes quiet like the engine isn't running then when I release the accelorator it goes back to idle? Has anyone else had this problem and could give me some advise? And could someone explain where the vacuum pipes go so I know they are right. Thanks for reading, matt.
Old Jan 25, 2014 | 08:47 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Cant use a 3bar map sensor. Try the Standard 2Bar and it might sort your issues. You WILL of course need a setup and tune to make it all run right.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
