running issues under load
Old Sep 22, 2013 | 08:12 PM
Turbo Al's Avatar
Turbo Al
Default running issues under load
my rs will start no bother, idle no bother and if i take the revs up slowly go all the way up and if i am hard on the throttle it pops, bangs, backfires and generally wont rev.
ive changed the plugs and they were very sooted up
changed the coil pack and leads as i thought the coil pack was breaking down under load but no joy
its not smokey but does have a strong petrol smell coming out the rs end
any ideas?
Old Oct 4, 2013 | 08:33 PM
Joe-FRST's Avatar
Joe-FRST
any ideas?
Quite keen to see people thoughts on this to, as mine does the same!
Old Oct 4, 2013 | 09:05 PM
frsjon's Avatar
frsjon
throttle position sensor would be my first thing to check after what you have changed already..
Old Oct 4, 2013 | 09:13 PM
Joe-FRST's Avatar
Joe-FRST
I am going to try crank sensor?
Old Oct 4, 2013 | 09:18 PM
frsjon's Avatar
frsjon
if the crank sensor wasnt working you wouldnt have any fuel or spark. if you have a spare then no harm in swapping them to check
Old Oct 4, 2013 | 09:26 PM
Joe-FRST's Avatar
Joe-FRST
That's true :/
Old Oct 4, 2013 | 09:36 PM
frsjon's Avatar
frsjon
if it was doing this once warm another one to check would be the coolant temp sensor but i take it these problems are from cold.
Old Oct 4, 2013 | 09:42 PM
Joe-FRST's Avatar
Joe-FRST
My issue is warm! I have a custom temp sensor.
Running 235 bhp so I might try upgrading injectors! They might be on the limit?
Old Oct 4, 2013 | 09:56 PM
frsjon's Avatar
frsjon
what ecu are you using joe?
Old Oct 4, 2013 | 10:02 PM
Joe-FRST's Avatar
Joe-FRST
Standard :/
Old Oct 4, 2013 | 10:15 PM
frsjon's Avatar
frsjon
why the custom temp sensor? you sure your not thinking temp sender? any way best thing mate would be to get it on the rollers,will find out pretty quickly what the issue is
Old Oct 4, 2013 | 10:36 PM
Joe-FRST's Avatar
Joe-FRST
Sorry, it's a temp sendor to a gauge.
Yeah I was thing of getting a omex 600 and taking it down to Motorsport developments to remap it.
Not sure how much they charge though :/
Old Oct 5, 2013 | 05:52 AM
Turbo Al's Avatar
Turbo Al
my ecu was the problem, had a broken track in it, i repaired it on thursday and its working fine now
Old Oct 5, 2013 | 10:55 AM
Joe-FRST's Avatar
Joe-FRST
Lol I will find the issue
Old Jan 2, 2014 | 11:43 AM
s1cosse's Avatar
s1cosse
It'll b the map sensor filter next to the ecu it has 3 wires going to it. Remove plastic for unit and reflow solder. I had it on mine tock me a wile to find give it a go
Chas
Sep 21, 2015 08:57 PM
Anutternutter
Aug 21, 2015 06:07 PM
yawiejon
15
Aug 9, 2015 06:36 PM
Red_bull
Aug 9, 2015 08:34 AM
