2 litre zetec conversion
hey guys i have fiesta si was interested in doing a 2 litre swap and wondered if anyone knew how difficult it was hard to get it in and what would i need
Iss really easy. You will need to put a 1.8 sump and oil pickup on the block to clear the fiesta subframe. Need a "DEEP" or "DESK" ecu and a 2.0 maf. Throw it all in and job done.
cool thought mounts etc would be a c*nt would i get all the 1.8 stuff of a mondy aswel then??? this sounds like it could be cheap enough to do but will the fez loom work???
Originally Posted by wirralphil
1.8 waterpump aswell???
the standard 1 then off my engine then thou sayin that i have a feeling i need a new 1 anyway.... chuffed now the task begins u reckon i could do it for 3-400 quid?!?! fancy having this done befor the first show over here in march. the damn thing is away at the min getting new sills front wings rear panel and fixed chassis rail
Originally Posted by Amy
I had that done to my XR2i when I had it and it cost me about Ł1500!!!
Seemed reasonable at the time!!
Don't do it like the Chopshop did it and transfer the front of the mondeo inc. suspension into the fiesta
Might be more info for you on www.fiestaturbo.com
Originally Posted by lukemakepeace
could i do that on my 1.6 escort? will the 1.6 loom etc be fine and does it just drop in and work?
Originally Posted by philpy-si
Didnt think the mondeo ecu would work in the fiesta wiring loom?
My megasquirt worked but overfueled hugely which was a pain in the ass
Mind you, my saph overfuels so damned if you do and damned if you dont. good job I like the smell of petrol eh?!
so do i use the fez ecu or the 2 ecus listed oh yea i for got to say manifold inlet and exhaust mondy or fez????
wud the si manifolds not fit? or the mondeo ones
i had a wee look at burton would one of the ashley manifolds do the job... mite have to keep the si stuff on it for a while until i build up the funds for a rebuild......
sunil what sorta power would i be expecting
not to bad for a fez with plenty of scope for more!!!! you say you used a focus inlet? off what one??
Im selling some R1 Carbs at the mo if you fancy more power than std
costs penuts if keeping enigine standard, what litre si do you have? if zetec use the exhaust manifold of it, sump and pick up and then all you need is a smaller oil filter on the mondeo pump, then a "deep, desk OR dewy ecu, mass sensor, throttle bosy and injectors otherwise is pointless".
my 2.0 in my old one cost me Ł70 from breakers, plus new sump gasket and few bits, shouldnt look over a Ł100 in parts if not having a rebuild
msportbo1 check his name on www.fiestaturbo.co.uk for his posts on the 2.0 fitment.
Originally Posted by luke89
Sunil_FiestaRS1800 you havnt got a rs1800 inlet have you ?
i have a trust electrical racing one but unsure wether to fit it dont wanan start fuckin about just want plug and play
No need to mess about using thw wrong ECU from a Mondeo:
http://www.megaefi.com/
With the RS1800 inlet this should see 150ish bhp.
Mondeo ecu is drivers side bulkhead you have to undo 2 10mm nuts in the engine bay and one in the drivers foot well and it comes out from the foot well easy as
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
