Differences between Zetec S Rear beam and FRST rear beam?
Old 18-07-2007, 06:54 PM
AGAR-COSWORTH
Redumbdancy
AGAR-COSWORTH's Avatar
Default Differences between Zetec S Rear beam and FRST rear beam?
As title really - what are the differences between the too - any pictures of either ones?
H196 JNE has advised me to fit 2 rear anti-roll bars to a FRST rear beam to stiffin the back up, im wondering if this can be done with a zetec s rear beam. Can a zetec s rear beam be fitted with an FRST ARB? Are two ARB's even neccessary with a zetec s beam?
Old 19-07-2007, 09:36 AM
Neil@FastFord
Neil@FastFord's Avatar
The twin roll bar on the FRST is something me and Jano from Oddkidd Creations did to my car for the magazine.
We did a full fitting guide in the July 07 issue. Call our back issues office for a copy
I cant remeber what a Zetec S looks like underneath, i'm sure it could be done.
It can be a little harsh for a road car though
Old 19-07-2007, 09:46 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
good to see some of the ideas from the mag features get seen and spoken about.
Old 19-07-2007, 10:30 PM
AGAR-COSWORTH
Redumbdancy
CHeers guys
Old 20-07-2007, 08:39 AM
zippyobrien
zippyobrien's Avatar
ive got a si, and the rear feels really soft,
so could i fit twin arb to the back otf that?
what do you do, use 2 standard ones? and then make brackets,
Old 20-07-2007, 08:56 AM
Neil@FastFord
Geez, you would'nt believe the response i have seen, in many PM's and several threads on various sites
Need to rig some time daaaaaawn in Essex again soon!
Old 20-07-2007, 10:56 AM
Versus_Creations
Ask me a question!
Wouldnt expect anything less from such a well known mag. I also see your motor on 3 wheels in the new mag out soon...
Old 20-07-2007, 10:59 AM
Oranoco
Oranoco's Avatar
Shout when your down fella I'll buy you a pint
Old 20-07-2007, 10:48 PM
AGAR-COSWORTH
Redumbdancy
Was down at Ford ordering a few bits. Got the guy at the counter to show me what the Mk5 Fiesta beam looks like on Microcat. There didn't appear to be any bolts/locations to connect the rear suspension struts into the beam?
Can anyone shed light on this? How on earth do people fit thier Mk3/3.5 rear suspension struts to the ZS beam?
Old 21-07-2007, 10:16 PM
2litresi
2litresi's Avatar
the zs beam fits straight on with no probs.also u can fit the focus rear discs to bolt straight up.
Old 24-07-2007, 12:14 PM
Neil@FastFord
Mate, i kicked the bollocks out of it, PROPER good fun!!!!
My pesky snapper didnt get the full crack though, god knows he had enough chances.
The lads were saying that i was about ten inches in the air when i was fuckin' about!
ORANOCO- Next time im planning a jaunt down i'll nudge ya stevo
Old 24-07-2007, 01:24 PM
Ken_ZS
Ken_ZS's Avatar
the shock bolts are jus below the hubs on the mk5 and micro cats view aint no good for them! make sure you get the right mountings for the mk5 beam cos some1 might try sellin ya a mk4 beam with the non parallel mounts
also u could go for the puma racin beam which is stronger i belive? not sure tbh but id go for the puma racin spacers to push the rear out cos the wheels on my Zs sit in to much where as the front wheels r smooth to the wing which i think the mk3s were the same? fronts sit out n rear in?
Old 25-07-2007, 11:00 PM
MikeyXR2i
MikeyXR2i's Avatar
I welded by original MK3 Rear beam up along the bottom to take the twist out of it, but im wondering now wether it was a good idea.
Old 27-07-2007, 09:47 PM
AGAR-COSWORTH
Redumbdancy
Cheers for yet more suggestions guys
Mikey - funny that, Rab suggested i do the same to my standard rear beam, im sure it'll be adequate enough for you and just as strong if not stronger than the ZS beam if you've boxed the underneath of the beam off.
Ken - No one has suggested the Puma beam before. Good shout! Will get in touch with Pumabuild and see if there is a difference between the Puma and ZS items.
Old 27-07-2007, 09:55 PM
MikeyXR2i
MikeyXR2i's Avatar
Hmmmm, ive drove the car a few times since i done it, felt good, completely different handling, Very hard though, have hard shocks though also. But yeah i boxed the bottom off and put more metal on the top corners where they put the metal originally.
Old 12-08-2007, 11:02 AM
zippyobrien
do oyu mean on the underside of the rear beam, wereits got a cavity,
is boxxing this recomended,
and how exactly do i fit to rear arbs?
i think ive got a spare one in the garage
when you boxed it i take it you rgot a strip of steel (what thickness) and welded it in? did you stitch it all the way along, or do it like seam welds???
Old 13-08-2007, 11:04 AM
KEVFRST
KEVFRST's Avatar
here are some snaps of a MK5 Beam, this is what Im using on my FRST.
you will notice the angle section is thicker, gusset ties are fitted to the end of the angle also.
I decided against fitting any brackets to use my original arb fromt he FRST beam, you do ned some flex in the beam or the car will skip around far tooo much.
09-10-2015 07:38 PM
Bosch
23-08-2015 12:31 PM
TrevCos
17-08-2015 09:08 PM
Bosch
04-08-2015 05:14 PM
Quick Reply: Differences between Zetec S Rear beam and FRST rear beam?
