big problem
Old Jul 12, 2006 | 04:54 PM
white2i's Avatar
white2i
Default big problem
this problem is on a FRST
hae just fitted a T3 to it, it won't start up, very thing connected, it has spark and fuel wen it's ment to get it, the wierd thing is if u take anyone of the spark plugs out it will run on 3 cylinder but it wont start on 4 cylinder
has anyone else had this problem or got any ideas as to what it is because i am stumped.
the only thing i can think of is it still has the same air filter that it did when it was running as T2, would this cause it to be starved of air??
cheers
marc
Old Jul 12, 2006 | 05:08 PM
Oranoco's Avatar
Oranoco
Nope as my T3 converted FRST is still on the same filter as well and that goes fine. My guess is you've disturbed something you shouldn't have during the conversion. I would start by checking all the multi plugs out. The fact you have fuel and a spark would indicated the CPS isn't at fault
Old Jul 12, 2006 | 05:18 PM
white2i's Avatar
white2i
cheers have checked all the multi plugs are connected and the wires are all good, i jus cant understandwhy it wont start at all m8
Old Jul 12, 2006 | 06:44 PM
5.03 sec 1600's Avatar
5.03 sec 1600
you say it starts with 3 cylinders linked up but not 4 linked up????????? let me have a think
Old Jul 12, 2006 | 06:58 PM
white2i's Avatar
white2i
yea it starts wid any 3 of them linked up but u hav 2 hav the spark plug out of 1 of them for it 2 start, then if u put all plugs in etc it wont start, got me baffled
Old Jul 12, 2006 | 07:36 PM
fezzanut's Avatar
fezzanut
did u use an escort manifold gasket as they are different to the fiesta?
Old Jul 12, 2006 | 07:42 PM
fezzanut's Avatar
fezzanut
http://www.fiestaturbo.com/forums/about119447.html
this might help
Old Jul 12, 2006 | 07:54 PM
white2i's Avatar
white2i
cheers m8 great help
na didnt now had 2 use a ERST manifold gasket, anyone now why you have to use it out of interest
Old Jul 12, 2006 | 08:01 PM
fezzanut's Avatar
fezzanut
i really dont know why but it says to on that guide.im wondering whether it might be blocking the flow of exhaust gases cos u say it runs with a plug out as the compression is being let out of the plug hole rather than being trapped in the cylinder if it is blocked.do a compression test on all 4 cylinders and see what they are
Old Jul 12, 2006 | 09:24 PM
white2i's Avatar
white2i
ok kewl, jus wondered, it does it on any of the cylinders tho if you let a plug out m8, gonna put ERST gasket on tomorrow and see if it makes any difference.
Old Jul 13, 2006 | 12:24 AM
jayRS's Avatar
jayRS
sounds like you got a vac leak or something.
have you checked fueses etc? checked for breaks in wireing/HT leads?
Old Jul 13, 2006 | 01:00 AM
white2i's Avatar
white2i
the fuses are all good and so are the vacuum hoses m8, as i say tho it will run on any 3 of the cylinders but not on four of them and to get it 2 run on 3 you have to take da spark plug out to get it to run.
Old Jul 13, 2006 | 05:00 PM
jayRS's Avatar
jayRS
are all ht leads and plugs working?
Old Jul 13, 2006 | 05:36 PM
white2i's Avatar
white2i
yea all ht leads and plugs workin m8, changed gasket to escort rst 1 and no difference, at this rate it gonnna get broken up
Old Jul 13, 2006 | 06:15 PM
jayRS's Avatar
jayRS
i really dont recommend this as i wouldnt do it myself but have you thouight of starting it on the 3 and sticking the 4th plug back in and reconnecting the ht lead?
Old Jul 13, 2006 | 09:57 PM
white2i's Avatar
white2i
tried that aswell and as soon as the plug gets in the hole it stalls the car m8, which is reli wierd, i mean i tried everything i can think of doin n still no where at the min,
was hopin someone would have some ideas i aint tried lol
cheers marc
Old Jul 13, 2006 | 10:00 PM
jayRS's Avatar
jayRS
done a compression test on it?
if its got a chip, take it out and try it.
have you fully charged the battery yet?
Old Jul 13, 2006 | 10:42 PM
white2i's Avatar
white2i
hav tried it with and without the chip, we hav done a compression test and they all seem the same and seem to be fine in my past experience. yea battery has been fully charged.
its jus such a wierd problem and am reli stuck with it know lol
Old Jul 13, 2006 | 11:17 PM
jayRS's Avatar
jayRS
ight be time to have a look under the rocker cover
Old Jul 13, 2006 | 11:21 PM
white2i's Avatar
white2i
ok m8 cheers will hav a look there 2mora cheers anyway you been a big help
Old Jul 13, 2006 | 11:27 PM
white2i's Avatar
white2i
rite just had a word with my m8 its his car not mine and he says he cant understand why it wont start was fine untill we changed the turbo,
the engine itself is 5500quids worth of full steel low comp bottom end etc and has only done 6k since it was built, it was run in with no boost for 1.5k of that aswell
cheers
marc
turbotrev
14
Sep 27, 2015 10:44 AM
Flateric_2002
Sep 15, 2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
