Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Mk5 zetec turbo help
Old Feb 8, 2012 | 03:01 PM
dude.james's Avatar
dude.james
Default Mk5 zetec turbo help
alrite lads just got a couple of questions about my zetec turbo project in a mk5 xr3i cosworth replica (on a tight budget)
Engine spec is;
2.1 with C20let pistons
HO inlet with 2.0 throttle body
custom injector rail with beige injectors
rs turbo manifold (drilled & tapped head)
RS turbo t3
looking for around 250ish bhp
Questions are...
what injectors would be best? ive found some rs turbo lightish blue ones that are claimed put out 345cc that are quite reasonably priced and would go straight in? i thought blue ones are as standard though?
http://www.pistonheads.com/sales/3593475.htm
My turbo needs rebuilding and i have been told that it will run out of puff at 200-220 anyway so which turbo would be better that can be picked up cheaply? or a upgraded compressor housing and turbine with a rebuild kit would be more cost effective? ive been told a cosworth turbo but if you put that on a rs turbo downpipe then the blower part of the compressor ends up pointing towards the engine so that could cause problems?
what intercooler could i use? had a look around and you can pick up some alloy front mounted ones that could go at the bottom of the radiator quite cheaply? also found some aftermarket alloy rs turbo intercoolers but would that fit onto a mk5 escort where it fits on the rs turbo? because down that the mk5's have got the washer bottle? but if i could get it there i could get some cold air feeds to it been the cosworth front bumper ive got quite a big grill at the bottom.
a gem on here is sorting the electrical megasquirt problems out for me so thats taken care of
any help is appreaceated and if people have got any parts that would suit up for sale that would help aswell
Old Feb 9, 2012 | 12:09 PM
studabear's Avatar
studabear
Have you got a exhaust system sorted yet? I've got 1 that was purchased for a project that never happened.
IIRC its a scorpion rst system adapted to fit a mk5
intercooler wise you have a few options, which all mainly include making it fit
Old Feb 9, 2012 | 12:13 PM
dude.james's Avatar
dude.james
Hi mate no i havent got one yet how much you looking? and is that to fit the rs turbo elbow?
and ive just bought an aftermarket intercooler mate with loads of diferent pipes and hosing so that should be fun to make fit
Just after some nice "cheap" 450cc ish injectors
Old Feb 9, 2012 | 12:15 PM
studabear's Avatar
studabear
its in my mates lock up, I will find out as not looked at it for a while but afaik it was to mount to T3 exhaust elbow.
Based in blackpool btw
Old Feb 9, 2012 | 12:17 PM
dude.james's Avatar
dude.james
would have to be posted mate?
and ok mate im trying to find out if the t3 exhaust housing will fit a cosworth t3 so i can use the downpipe for rs turbo?
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
