Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
gti progect
Old May 1, 2011 | 08:04 PM
tez67's Avatar
tez67
Default gti progect
hows it going, can any one tell us what engines can be put into escort gti r reg.
Old May 10, 2011 | 01:07 PM
kenna_86's Avatar
kenna_86
Any engine fits. Its just the amount of effort your going to have to put into it. What sort of power are you looking for?
Old May 10, 2011 | 05:04 PM
vinnyvangough's Avatar
vinnyvangough
Lol.
Depends on budget.
If you got the cash you can fit anything. Best bet and probably easiest is the Mk1 Mondeo 2.0l Zetec
Old May 10, 2011 | 07:41 PM
tez67's Avatar
tez67
cheeeeeeeeeeers everyone for your reply's, probaly just try do some mod's on the engine i have.
Old May 12, 2011 | 12:17 PM
STeve's Avatar
Super Moderator
should be able to reach 140bhp with some well thought out mods on the standard 115 stock unit,without going into mega money with a turbo unit
Old May 17, 2011 | 10:53 AM
fonfe123's Avatar
fonfe123
but for the money your going to spend to reach that 140bhp is by far cheaper to buy a standard rs2000 engine and fit it with no hassle or problems. i paid £100 for my last one!
Old May 22, 2011 | 09:20 AM
STeve's Avatar
Super Moderator
yeah if it was off the shelf parts I agree ,recently done the required mods on one of these engines all for the sum of £20 using salvage parts from breakers
Old May 24, 2011 | 08:02 PM
sdrdave's Avatar
sdrdave
Will the RS2000 engine fit though without any major hassle though? Doubt it, probably easier to mod what you already have
Old May 31, 2011 | 01:20 PM
fonfe123's Avatar
fonfe123
yes it does. just swap everything from one to the other. same car diff engine and gearbox setup.....
you can run the zetec ib5 box if you just want the engine and not bothered about box and suspension just use a zetec flywheel and clutch.
Old May 31, 2011 | 01:25 PM
Mike C's Avatar
Mike C
The Special One
I put a Subaru EJ257 in my R-Reg GTi, but it wasn't exactly straightforward, lol.....
Easiest and most cost-effective is a 2.0 Zetec-E as said.
Makes more of a difference in reality than the figures on paper would suggest, although the standard 1.8 Zetec-E makes for an easier/cheaper base for a "budget" Zetec Turbo.
Old May 31, 2011 | 11:51 PM
GTi Kid's Avatar
GTi Kid
Changing to a 2L Zetec is alot of hassle for a 15BHP gain just use the throttle body MAF sensor cams and ecu from said 2L easy swap and should give power output of around 150-160hp
Old Jun 1, 2011 | 06:12 AM
mattxr3i's Avatar
mattxr3i
how?
What you have described there is basically the 130spec upgrade........
Old Jun 1, 2011 | 04:41 PM
GTi Kid's Avatar
GTi Kid
[quote=mattxr3i;5485376]how?
What you have described there is basically the 130spec upgrade........[/quote
quite simple the 2l throttle body is a direct fit but with a larger butterfly allowing more air but need the maf and ecu to control the fuel its basically modding the engine with standard parts
Old Jun 1, 2011 | 05:07 PM
vinnyvangough
150-160bhp, lol.
Best thing i read all day. You'd be lucky to see anymore than 130bhp
Old Jun 16, 2011 | 11:58 AM
rapidonion's Avatar
rapidonion
lol ive got a mk6 gti as well as my turbo orion ive put the 2.0 cams maff and throttle on as well as a plug in chip and would love it to be 150/160 bhp............................................... .......but it aint lol
Old Oct 19, 2011 | 06:45 AM
danielson04's Avatar
danielson04
Lmao qualityy!!
Old Oct 19, 2011 | 07:51 AM
STeve's Avatar
Super Moderator
keep smoking them jamican woodbines fella 150/160 bhp with them mods , only if being towed by a RS2000
liamT74
Sep 23, 2015 10:24 PM
Vacuman
17
Sep 18, 2015 04:42 PM
cossirob
Sep 16, 2015 07:39 PM
nikki.n.tom
Sep 15, 2015 08:20 PM
cossirob
Aug 31, 2015 09:53 PM
