Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
rs2000 mk6 headbolt
Old Feb 19, 2010 | 02:35 PM
rossscott's Avatar
rossscott
Default rs2000 mk6 headbolt
does anybody know the torque settings for the 10 headbolts when doing a headgasket on a 1996 rs2000?
Old Feb 21, 2010 | 08:22 AM
Icurus's Avatar
Icurus
1st stage - 40nm
2nd stage - 55nm
3rd stage - 90 degrees
4th stage - 90 degrees
Old Feb 21, 2010 | 02:18 PM
rossscott's Avatar
rossscott
thanks do you know timeming marks for crankshaft position and valve marks position
Old Feb 21, 2010 | 07:15 PM
Icurus's Avatar
Icurus
The newer timing chains will have some gold links, 2 pairs and a single.
The crank sprocket has a mark that needs to be pointing downwards to 6 o'clock whilst the cams have marks the need to be pointing to 9 o'clock for the inlet and 3 o'clock for the exhaust. You should now be able to wrap the new timing chain around the sprockets and have the cams marks in-between the pairs of gold links, and the cranks sprocket in the single gold link.
I'll see if I can get a picture for you.
Old Feb 21, 2010 | 07:28 PM
rossscott's Avatar
rossscott
Default RS
thanks for that,only thing is i am useing chain with no gold links is there away round this or do i change timing chain
Old Feb 21, 2010 | 09:39 PM
rossscott's Avatar
rossscott
i have done as you said but i am still having trouble when i hand turn /valves hitting pistons 2 and3 any ideas
Old Feb 21, 2010 | 10:31 PM
Icurus's Avatar
Icurus
You need to have the piston part way down the bore on number 1, abouy 25mm BTDC, then set the cams, then bring number 1 piston to TDC.
Best to get a new chain as the gold links are really the key to setting the timing with no other data to hand.
www.rs2000-16v.com has some ford manuals that cover this procedure.
Chopshop85
Oct 22, 2015 09:26 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
Vacuman
Sep 22, 2015 12:09 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
