Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
RS2000 question
Old Mar 6, 2008 | 07:20 PM
Maki's Avatar
Maki
Default RS2000 question
my friend has a problem, after cold start rewes keep on playing up and down until the car warmes up. What could be the problem?
Old Mar 7, 2008 | 08:26 AM
slimrs2k's Avatar
slimrs2k
I judst sold mine mate, it idled up and down when cold the problem was traced to a fuse on the limp home programe by my local ford dealer
Old Mar 7, 2008 | 01:40 PM
kitchy's Avatar
kitchy
RS2000 4x4
could also be an airleak causing erratic idle,
Old Mar 9, 2008 | 09:07 PM
Maki's Avatar
Maki
Originally Posted by slimrs2k
..fuse on the limp home programe
explain please???
Old Mar 10, 2008 | 11:26 AM
dave green's Avatar
dave green
idle control valve,?
Dave
Old Mar 10, 2008 | 06:51 PM
lincolnrs's Avatar
lincolnrs
Sounds like a dodgy ICV
Old Mar 11, 2008 | 04:47 PM
Mark_'s Avatar
Mark_
as above, sticky icv
Old Mar 11, 2008 | 05:30 PM
Check the lambda is not slow.
Old Mar 11, 2008 | 07:52 PM
rs nuts's Avatar
rs nuts
i too have the same problem , tabetha i have checked the lambda , and yes it moves across slowly on the machine , like the signal from it too the ecu is poor , what does that mean
Old Mar 11, 2008 | 09:03 PM
You need to have a fast emough switching speed, from the lambda, as they slow with age, and will cause your symptoms, as they do not react quick enough to mix changes.
Old Mar 11, 2008 | 09:42 PM
rs nuts's Avatar
rs nuts
cheers for that , ive just been told too unplug the idle control valve aswell when running
and it should stall , if not i have an air leak ,and mine dosent stall, so i have listened around the inlet manifold and yes i can hear hissing around the injectors
been told too renew the rubber o rings around the injectors , have you heard off that before
sorry for the hi jack on post , but it may help your mate out aswell , as i have been told this is a common problem on these cars
Old Mar 12, 2008 | 01:02 PM
stuey650's Avatar
stuey650
Yes this is common and you can't get the O rings from ford no more. Apparently B&Q sell rings that fit though. The other thing to try is to take them out, freeze them , then dunk them in boiling water and refit. This can soften them up enough to seal the injectors again.
Old Mar 12, 2008 | 02:37 PM
slimrs2k's Avatar
slimrs2k
There was a dodgy fuse in some part of the ECU which meant that it was on the limp home programe all the time, so it ran really poor, it took my local ford garage three goes to diagnose the problem, as the computer on the car wouldnt talk to the diagnostic machine, it was only by chance when they check the fuses that they found one was bust. Not quite sure why it went to limp home but as soon as they changed the fuse it was like a different car, didnt idle all over the place and pull like a train. The mechanic siad he'd never known it happen before mine
Old Mar 12, 2008 | 07:34 PM
rs nuts's Avatar
rs nuts
ok mine did have an air leak on the rubber seals , that now has been sorted , but the car still idles rough and uses a lot off fuel
TABETHA , checked again today and the signal is a lot slower than normal , that i see on other cars
doo you think they need replaceing ? been told today just too unplug them , and the car should run smoother , if it does i should replace them , is that good advice
Old Mar 12, 2008 | 09:32 PM
Maki's Avatar
Maki
Interesting ways, so what are the sugestions?
I tried to unplug the ISCV and the car did stall, so thats not it. The other thing about the leak and lambda... how do you check lambda for being slow??
Old Mar 12, 2008 | 09:36 PM
nickscunny's Avatar
nickscunny
mine did all of the above, i changed the air-bypass valve and a decat later she was a reet train!!!!
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
