Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
16i Running Problems - When Warm
Old Oct 2, 2003 | 12:45 PM
LeeBuckman's Avatar
LeeBuckman
Default 16i Running Problems - When Warm
I have a RS1600i which at the moment is ok apart from when the engine is up to running temp. When dipping the clutch to change gear or coming to a junction and changing down, the revs drop off and the engine will stall. For example, I drove the car up the road yesterday and changed from 2nd to 3rd and left my foot on the clutch to see what happened and the revs died off completely and the engine stalled. The engine started again once i released the clutch (effectively jump starting a moving vehicle)........ Can anyone help with this problem or make some suggestions what might be wrong.
Thanks In Advance
Lee
Old Oct 2, 2003 | 01:03 PM
paul cox's Avatar
paul cox
it does'nt happen when cold then ???
only when hot ???? - whats the read out on the temp gauge ???
how much fuel you got in the tank ??
does it stall in tops gears ???
me thinking fuel pressure >>>> - at the moment
Old Oct 2, 2003 | 04:10 PM
LeeBuckman's Avatar
LeeBuckman
Temp gauge is about half way. Does not seem to do it when cold but have not really driven car enough to say for sure. Tank is over half full with fresh petrol and car seems to tick over ok at approx 975rpm. Have not really experimented with the top gears too much but would not be suprised if it did the same thing when cold.... With regard to the fuelling, does not seem to misfire and has new fuel pump on car.................
Thx
Lee
Old Oct 2, 2003 | 04:20 PM
Clare's Avatar
Clare
Your temp gauge is sitting half way at normal running temperature??? Blimey, mine sits just over the white marker except when im sat in traffic, thats the only time she raises that high!
Mine was doing what you've described but when it was cold, not hot, was just my idle speed.
Old Oct 2, 2003 | 06:10 PM
paul cox's Avatar
paul cox
try taking the plugs out - see what colour they are 1st.
also - check that all the vacuum lines are conected,from the rocker cover - from the throttle body - from the plenium chamber - from the air flow meter area.
also - try just upping the idea slighty - see if that cure's the problem ???
lets us know - try and help you next step - okay
Old Oct 2, 2003 | 06:30 PM
paul cox's Avatar
paul cox
about time pete - well said , easy as that
Old Oct 2, 2003 | 06:31 PM
pete-rsi's Avatar
pete-rsi
Try cleaning the throttle housing with carb cleaner making shure the air filter is clean adjust idle screw so just to get it idling then have the Co checked and for any air leaks then adjust idle to suit, would'nt go looking for the complicated stuff just yet it's normally something simple
Where abouts are you by the way - somebody may be close to help.
Old Oct 2, 2003 | 06:37 PM
pete-rsi's Avatar
pete-rsi
How did you know I was going to say that
Old Oct 2, 2003 | 06:55 PM
paul cox's Avatar
paul cox
just magic
just re-set the clock again
Lee - keep us informed,as to how it is going ???
Old Oct 2, 2003 | 09:17 PM
LeeBuckman's Avatar
LeeBuckman
Thanks Folks. Have spoke to another 16i Guru locally who said he is adamant the car just need setting up properly. He said much the same and said to make sure the right plugs are in it with right gap. Clean/Replace AIr Filter/Idle screw/Throttle Housing and adjust mixture etc.... I'll keep u posted.
Also, have problem when starting when hot but suspect it is just the starter motor. SOmeone else i know had a 16i that would only start from cold till he replaced the starter. Sound FAmiliar anyone ???
Thanks Again
Lee
Old Oct 2, 2003 | 09:35 PM
pete-rsi's Avatar
pete-rsi
If it's slow and reluctant to turn over when cranking (hot) = Starter motor
Old Oct 3, 2003 | 03:54 AM
kvflatman's Avatar
kvflatman
Sounds like my misses bless her
Old Oct 3, 2003 | 07:25 AM
paul cox's Avatar
paul cox
nice one Lee - keep telling us whats wrong
good learning curve for all of us
Old Oct 3, 2003 | 08:03 AM
It's Czech Mate's Avatar
It's Czech Mate
Try replacing the fuel relay and checking your vacuum hoses. Get it set up and I'll betcha that solves it as it's exactly what mine did when I had it.
Keep us all posted
Old Oct 3, 2003 | 11:38 AM
Clare's Avatar
Clare
The hot starting problem could be the same issue that all Mk3 1600i escorts had, the alternator solenoid getting too hot and stops working. Once cooled down it starts working again.
Symtoms are:
When stationary for a long time and the engine gets warm enough for the fan to kick in, then you switch the car off and immediately try and re-start it, it either appears to have a dead battery or is very slow and sluggish turning over.
Good luck in sorting it out thou, just remember, we're all in the same boat and we all drive tempremental cars that often throw hissy fits!
Old Oct 3, 2003 | 12:16 PM
paul cox's Avatar
paul cox
clare - mine dont (not yet anyway)
good luck - lots of things to try out now ???
Old Oct 3, 2003 | 12:49 PM
Clare's Avatar
Clare
Not every car will suffer with the problem Paul, but it is a known fault with the Mk3.
Old Oct 3, 2003 | 01:06 PM
paul cox's Avatar
paul cox
ahhhhhhhhhhhhhhhhhh
just around the corner for me then
Old Oct 3, 2003 | 06:52 PM
Quickie's Avatar
Quickie
Get a series2 RST heat shield from fords to fit on yer starter stops them from getting TOOOO hot worked on mine A diesel starter motor out of an escort fits a lot more heavy duty than a std item
Old Oct 3, 2003 | 07:02 PM
paul cox's Avatar
paul cox
quickie - you've got some S2 stuff then,on your motor !!!!!
yo-yo-yo , big up to ya man !!!
Old Oct 3, 2003 | 07:06 PM
Quickie's Avatar
Quickie
SSSSSHHHHHHH dont tell everyone
Old Oct 3, 2003 | 07:10 PM
paul cox's Avatar
paul cox
Old Oct 3, 2003 | 07:14 PM
Quickie's Avatar
Quickie
It was a secret
Old Oct 3, 2003 | 07:31 PM
paul cox's Avatar
paul cox
its oh so quite
dont mention the ????????????
Old Oct 3, 2003 | 07:35 PM
Quickie's Avatar
Quickie
I thought i would pass on the helpfull tip
Old Oct 3, 2003 | 07:42 PM
paul cox's Avatar
paul cox
and very usefull it is to
Thanks mr quickie
helpful as ever
Old Oct 3, 2003 | 07:45 PM
pete-rsi's Avatar
pete-rsi
Yes but S2 diesel bits
and a sig test - i thank you and Alan.
Old Oct 3, 2003 | 07:46 PM
Quickie's Avatar
Quickie
LOL
Old Oct 3, 2003 | 07:48 PM
paul cox's Avatar
paul cox
pete - looks nice matey !!!!
S2 bit's - love it (shall i put my S2 engine in the RSI ??)
Old Oct 3, 2003 | 07:59 PM
pete-rsi's Avatar
pete-rsi
no the diesel
Old Oct 3, 2003 | 08:02 PM
paul cox's Avatar
paul cox
thats kev's 3 cylinder RSI !!!!
Old Oct 3, 2003 | 08:06 PM
pete-rsi's Avatar
pete-rsi
Of corsa! it is
Old Oct 3, 2003 | 08:07 PM
paul cox's Avatar
paul cox
thats no corsa - even though kev did win the "vauxhall t-shirt"
Old Oct 3, 2003 | 08:10 PM
pete-rsi's Avatar
pete-rsi
Quickie will get it aaarrrrrhhhhhh
Old Oct 3, 2003 | 08:12 PM
paul cox's Avatar
paul cox
will he now ???
he has had some cornish air in side him !!!!!
Old Oct 3, 2003 | 09:41 PM
Quickie's Avatar
Quickie
Cornish beers fugged me up a bit
Old Oct 3, 2003 | 09:44 PM
pete-rsi's Avatar
pete-rsi
and plugged you up a bit - i bet
Old Oct 4, 2003 | 07:43 AM
paul cox's Avatar
paul cox
"bang"
any pastie's ??????
Old Oct 4, 2003 | 01:51 PM
kvflatman's Avatar
kvflatman
Old Oct 4, 2003 | 01:54 PM
Quickie's Avatar
Quickie
Yep had some pasties and brought some home
