Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Running problems
Old Sep 20, 2006 | 04:27 PM
StewartRST's Avatar
StewartRST
Default Running problems
I have recently had a problem with my 16i, i have replaced the leads, coils, but it still miss fires every so often, normally in traffic whe idleing and you go to pull away or around the 2700 rpm mark, it cuts out and then will not restart just keeps popping and not starting any ideas
Old Sep 20, 2006 | 05:24 PM
GraphiteGray's Avatar
GraphiteGray
Have you tried changing the ECU and/or gearbox sensor lead?
if you havent any spares try ebay
Old Sep 20, 2006 | 05:33 PM
XR2's Avatar
XR2
Or a problem with the flywheel. Is also common on the RSi's
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
