plastic headlights
Old Oct 25, 2013 | 01:21 PM
STeve's Avatar
Super Moderator
Default plastic headlights
have some plastic headlamps that have become almost blurry, what product can be used to restore them back to clarity
Old Oct 25, 2013 | 01:33 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Obviously I'm an amateur when it comes to products but I always t-cut repeatedly and they usually come up clear. Although one of the puma lights is being stubborn
Old Oct 25, 2013 | 03:32 PM
BigChuck's Avatar
BigChuck
anything with a cut in it will do, i used g3 as i had some handy. you may need to go through the stages with wet n dry if they are particularly bad.
make sure you seal them after wards to help stop them going the same way.
Old Oct 26, 2013 | 08:32 PM
JamboRS's Avatar
JamboRS
focus rs 1672
done my xenons
started by wet sanding using 1500 then 2000 then 2500 then 3000.could see by this point that they were looking very good.so machined them using 3m fast cut then refined with menzerna. gtechniq c4 was used to seal them then 2 coats of coli 476.im pleased with how they turned out
before
after
its important to seal them afterwards as they will yellow as headlights come from factory with a uv coating
Old Oct 27, 2013 | 06:37 AM
STeve's Avatar
Super Moderator
Wow they look stunning
Old Oct 27, 2013 | 10:24 AM
SBT83's Avatar
SBT83
What a difference!! So am I right in guessing you have to seal them, say everytime you wash? Or does the seal stand up to the weather for a while?
Old Oct 27, 2013 | 07:53 PM
STeve's Avatar
Super Moderator
did mine today with some cutting compound and was chuffed to bits with outcome, just had some autoglym resin polish to seal them but was well impressed
Old Oct 27, 2013 | 07:55 PM
costina's Avatar
costina
Live long and prosper!!
Brasso works well too
Old Oct 27, 2013 | 08:38 PM
JamboRS's Avatar
JamboRS
focus rs 1672
I sealed them with gtechniq c4. It needs to be sealed with a uv protectant as its uv light which fades them. Ag resin polish is no good mate.
Old Oct 28, 2013 | 07:01 AM
STeve's Avatar
Super Moderator
if I come across some of the correct stuff I will do them again, best I could do with what was in my shed
Old Oct 28, 2013 | 04:08 PM
I could do with doing the poomas head lights cause they are starting to go a bit shity.
Old Oct 28, 2013 | 04:11 PM
phil_rs's Avatar
phil_rs
yam yammer
Wet sand and machine polish is the only proper way
Old Oct 28, 2013 | 04:57 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
roughly how long should it take per lense? are we talking a couple of hours rubbing?
Old Oct 29, 2013 | 08:12 AM
Brian's Avatar
Brian
Halfords sell a Meguiars headlight restoration kit that's ment to be good
http://www.halfords.com/webapp/wcs/s...5233&langId=-1
Brian
Old Oct 29, 2013 | 03:54 PM
JamboRS's Avatar
JamboRS
focus rs 1672
I spent a couple of hours on mine to get the perfect. Could prob get away with 30-40 mins per lense, thats wet sanding them and polishing.
Old Oct 29, 2013 | 04:00 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
I used the Meguiars kit and it worked really well.
Old Oct 29, 2013 | 05:06 PM
STeve's Avatar
Super Moderator
thumbs up for the Meguiars kit then, thanks guys
Old Oct 29, 2013 | 05:35 PM
fuzzy's Avatar
fuzzy
i suppose i should have given it more than 5 minutes then before giving up?
Old Oct 29, 2013 | 05:47 PM
SBT83's Avatar
SBT83
Old Oct 29, 2013 | 06:12 PM
phil_rs's Avatar
phil_rs
yam yammer
Takes me roughly an hour to wet sand and machine polish
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
