snow foaming problem
Old Oct 6, 2013 | 11:21 AM
andyb30's Avatar
andyb30
Default snow foaming problem
hi guys recently brought a kartcher pressure washer and a adjustable foam lacne the problem is the foam just runs of the car a dose not stick so dose not have time to work properly. is there something im doing wrong or is the lance/washer at fault ??
Old Oct 6, 2013 | 12:10 PM
Jay,'s Avatar
Jay,
Sponsor
Try adding a bit more foam solution and turn the lance up a bit to
Old Oct 6, 2013 | 03:03 PM
matts1's Avatar
matts1
as said, try more solution and mess about with adjustment on the lance, what lance did you buy? and what snow foam?
Old Oct 6, 2013 | 06:28 PM
BRAMMER's Avatar
BRAMMER
Dependant on solution , the best i've used is Autobright Magifoam and that covers the car with a nice thick layer whereas the valet pro stuff is proper poor and only puts a thin weak layer on so you have to treble up the solution just to make it worth it.
Old Oct 7, 2013 | 10:36 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
valet pro is poor to say the least, 50% mix in the bottle is ok, but an expensive way to do it.
i even machined the lance a bit to help it flow more fluid to thicken it up if i needed.
i'm using a c120 nilfisk and heard mixed opinions, thought it was that at first, but seems to be the valet pro2 fluid to blame.
Old Oct 13, 2013 | 08:02 PM
gingeRS's Avatar
gingeRS
I use valet pro about 1:10 with water in a proper lance with a nilfisk 120 and get nice thick foam?
Old Oct 13, 2013 | 08:16 PM
P4ULT's Avatar
P4ULT
Do you rinse the car before using the snow foam as I always find it better to put the foam onto a dry car, then rinse.
Old Oct 14, 2013 | 08:09 AM
Ive always wet the car first then used the snow foam....
Old Oct 14, 2013 | 08:47 AM
Rowe's Avatar
Rowe
Skint
i use valet pro neat, its that wank.
You won't go wrong with chm guys no touch, or AB magifoam (get the regular stuff, not the coloured)
Old Oct 14, 2013 | 08:27 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i did 50/50 and is was still crap, tried all sorts of ratios and nothing seems to work particularly well, that said, stay away from JWAC, proper poo stuff.
i think when i run out of the VP, i'll get something much better, quite like CB's gear.
Old Oct 16, 2013 | 07:59 PM
andyb30's Avatar
andyb30
hi guys thanks for all ya tips will give it ago at the weekend and let you know how i get on
Old Oct 16, 2013 | 08:44 PM
AJC's Avatar
AJC
I had same problem. I had a karcher foam lance.
I bought Auto brights lance and auto brite magi foam.
Difference is phenomenally better with the AB stuff.
Old Oct 17, 2013 | 07:30 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Yeah I had the Karcher lance and IMO I think they are a bit cheeky calling it a foam lance as I felt it was more of a shampoo lance.
As AJC did I got an AB lance and AB magifoam entry combo and hey presto foaming goodness.
Currently using CG Mr Pink in the lance and the buckets and once again foam tastic fun
Old Oct 17, 2013 | 09:40 PM
PhoneShopRS's Avatar
PhoneShopRS
Default Which form is best to get
Am thing if purchasing some is I Auto brights lance and auto brite magi foam the best to get
Old Oct 17, 2013 | 10:15 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
All I can say is it does the job very well and at the time of purchasing it was one if the best deals around.
The lance is good and solid with plenty if mix adjustment and the bottle is more than enough to do a car
I have however noticed other lances that look identical but wit a black nozzle but can't vouch for the quality.
The Magifoam is a good product and does exactly what it's meant to
Most snowfoams are per-cleaners and should be treated as such, it just the good ones will do more than just per-clean and leave less work when actually cleaning the car properly.
Depending on how clean the car is or the time since I last did it I can get away with a snowfoam and rinse if I can only get a quick spruce in.
Product so far I have had no complaints with are
• AB Magifoam
• CG Mr Pink (shampoo which you can also use as foam)
I have also used Car Plan Demon Snow which is also pretty good and easily available
This my current weapon of choice
Old Oct 20, 2013 | 01:39 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Its not just about the type of foam and % of foam,the pressure washer you use makes a difference aswell as water pressure and temps
For example I can use my nilfisk with the same foam lance with the same ratio mix,the water supply from the same source with same pressure and temps etc
And my Kranzle can foam twice as thick.
Old Oct 20, 2013 | 03:03 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Good point Also different water supply pressures make a difference. Where I live in Hertfordshire the water pressure is awesome in fact too strong at times but my old man's place one mile up the road in Hillingdon has less pressure which makes the foam a bit thinner and more tweaking is involved
DAZZER
Sep 30, 2015 08:43 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
